Fork Tubes
Old May 7, 2010 | 09:25 AM
bucket13's Avatar
bucket13
Default Fork Tubes
Do fork tubes impact the performance\stability of the front end? Or are all fork tubes created equally?
Thanks
Mat
Old May 7, 2010 | 01:25 PM
SC-Longhair's Avatar
SC-Longhair
Depends I guess.
You have 49mm forks. They're pretty stiff. I can't see them flexing under load. The pre-06 wide glides had 41mm forks and all other harley's had 39mm forks.
There are 3rd party manufacturers...ceriani for instance. Their front ends are used on a lot of sport bikes. So, by that you could probably determine they are a better product because sport bikes handle excellent up to some intense speeds.
Old May 8, 2010 | 07:36 AM
8541hog's Avatar
8541hog
Yes, the tubes can impact performance/stability. But not sure one brand of tube is better than another given the same length, diameter. and mounting design.
Not quite a fair comparison to a sport bike tubes, as most sport bike tubes are quite a bit shorter than most HD tubes which would naturally make them more rigid when installed.
Just curious why you are asking?
AllenW
Sep 19, 2019 04:17 PM
crtman21
Aug 23, 2016 08:12 AM
MegaFauna
Aug 4, 2015 03:54 PM
chappy99
Oct 9, 2011 10:41 AM
fxlr_93
Dec 11, 2010 09:04 AM
