Street Bob low oil?!
Old Jul 15, 2015 | 04:34 AM
target64's Avatar
target64
Originally Posted by noraA
Looked around the forum more and found what you meant about venting externally. Found this thread to be specific http://www.hdforums.com/forum/tourin...-included.html and now will order the house kit from DK
here is a pic of my modify backing plate. the oil mist goes into the external filter. have not had any oil residue on the engine case sense modification.
Old Jul 15, 2015 | 04:44 AM
TinCupChalice's Avatar
TinCupChalice
If this is the style of intake you're interested in why not order the DK Custom 636v complete kit instead, it's designed from the ground up for use with external breathers. With the kit you've pictured you'll be modifying it to set it up for external venting, the DK Custom 636v kit will make your install much simpler and their breather bolts work very well, I'm running them with their 587 intake on my '13 Wide Glide. You can also add their discrete breather kit when you order their intake if you prefer that style: http://www.dkcustomproducts.com/Outl...636V-TC-CS.htm
I won't worry too much about valves at this point, this is most likely operator error Your oil level should be between the full and add marks on the stick on a cold check, no more. I don't worry about seeing how much mileage I can get from spendy synthetics, instead I use VR1 SAE 50 weigh oil and just change it more frequently, I have no oil carry over into the breathers; running breather bolts it would be all over the bike if there was. These are air cooled machines and you should be checking your fluids on a continuous basis, if you find your cold check is not at the middle of the stick it only takes an ounce or two to put it back where it belongs; overfill and the oil carry over ends up out the crankcase breathers and if you're not venting to atmosphere that carry over gets puked back into the intake and engine... and that's nasty
Old Jul 15, 2015 | 10:14 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Both of my Dyna's oil level cold is about 1/2 inch from full. My 13 Road Glide is at the level HD recommends on the 103 engine. We just returned from a 1800 mile trip out east and back with no loss of oil, the 103 engine. Around town the 88 and 95 uses nary a drop of oil. Did you check your plugs, if they are black and sooty you have other problems. The setup have will vent oil vapors but the oil will condense in the little breather and then eventually start dripping on the cases. Good luck.
Old Jul 15, 2015 | 10:30 AM
soft 02's Avatar
soft 02
nevil
Sep 27, 2016 11:49 AM
DYNA5994
General Topics/Tech Tips
May 18, 2016 01:35 PM
AAAC
EVO
16
May 11, 2015 06:54 PM
2XNightTrain
Jul 26, 2011 06:07 PM
skeetas
Jul 9, 2006 01:18 AM
