Map question
Old Aug 13, 2015 | 08:24 PM
Delldoe3030's Avatar
Delldoe3030
Default Map question
Is anyone running a softail map on there dyna? Both 88's softails are a 88b I believe through previous research which just means balanced? Its the closest map I can find so I'm gonna put it in there and test ride if I'm making a big mistake or should t use it someone please stop me.
Old Aug 13, 2015 | 08:40 PM
dirtdobber's Avatar
dirtdobber
As long as the components are the same it should be fine.
What tuner are you using?
Old Aug 13, 2015 | 08:47 PM
Delldoe3030
Running the PCV it doesn't run real good slight pop after letting off the throttle only difference in the map is I'm running a rsd A/C instead of a SE.
Old Aug 14, 2015 | 01:47 AM
dirtdobber's Avatar
dirtdobber
Just save the map you have and try the other out. Did you get it from fuelmoto?
if you did you have a life time support for maps, free
Old Aug 14, 2015 | 03:15 AM
Delldoe3030
No I messed up and got one off eBay saved a few bucks but that was before I read all the great reviews on here about fuel motos tech/map support!!
Idahokid
13
Apr 28, 2018 07:36 AM
scooper321
Sep 10, 2016 10:13 AM
SnoRider
Aug 22, 2016 03:21 PM
kryingame
Nov 13, 2015 07:57 PM
Weeboy1
Jun 10, 2015 02:49 PM
