H-D Dealer Service Fail
Old Aug 18, 2015 | 01:55 PM
Geoff's Avatar
Geoff
Default H-D Dealer Service Fail
Took my '03 Low Rider to a dealer last Saturday to have a knocking noise checked out. The tech removed the primary cover, made an inspection and concluded the noise was coming from the top end of the motor. The dealer quoted me $1,000 to open up the motor and determine what's wrong. I'm no mechanic, but when I listened to the motor, the knocking was definitely coming from the primary. I told the dealer no thanks and rode home.
Yesterday, I took my bike to an independent shop. Within minutes after removing the primary cover, they discovered the bolt securing the compensator needed to be torqued. A handshake and $45 later, I was on my way.
I thought the HD dealer deserved some feedback on my experience, so I called the service manager. I explained how the tech misdiagnosed my problem and the $1,000 quote. He said he appreciated my call and would talk with the tech.
Old Aug 18, 2015 | 01:58 PM
Clayvis's Avatar
Clayvis
Precisely why I do all my own work....
If that's not possible for you, then stick with an honest independent...guess you know that now! Live and learn
Old Aug 18, 2015 | 06:09 PM
Gadgetech's Avatar
Gadgetech
And give him a pat on the back, heh. He's probably thinking, $1k quote? That's doing your job son. Don't worry about losing that one though, there's plenty of others that will fall for it.
Old Aug 18, 2015 | 07:42 PM
Geoff's Avatar
Geoff
LOL!
It does make you wonder.
Old Aug 18, 2015 | 08:04 PM
kontiki's Avatar
kontiki
Not all dealers are the same. Sounds like the one you went to needs to hire some better techs. May have to offer to pay more to get better quality ones.
Old Aug 18, 2015 | 10:24 PM
gomiller2's Avatar
gomiller2
Yep and don't forget to tell your brothers what indy hooked you up.
Old Aug 19, 2015 | 02:32 PM
Geoff's Avatar
Geoff
Kalbo's Performance Cycle, Joliet, IL
http://www.kalbosperformancecycle.com/
Old Aug 19, 2015 | 02:41 PM
jricharc's Avatar
jricharc
Exactly why I do all that I can myself.
Old Aug 20, 2015 | 08:31 AM
Geoff's Avatar
Geoff
I'd do more work myself if I had time. I travel with work. When I have free time at home, I'd much rather ride than wrench.
Old Aug 20, 2015 | 01:27 PM
dirtdobber's Avatar
dirtdobber
I had our flrt serviced, 1,000 mile service. I noticed a knocking when i took off when it had not warmed up completely. Coming from the compensator. Then i heard it in the clutch area. Done some research. Drained the primary, 28 oz drained out. I put in 38 oz as the manual says. Knocking was gone. Completely.
i called and reported it. They said not to over fill it??
so, some of the techs are putting in 32 oz instead of tbe required 38 oz.
if you have the new compensator and occur any knocking at times I suggest checking it.
made a difference for sure
I do almost all my service myself.
TriGeezer
General Topics/Tech Tips
11
Apr 23, 2017 12:34 PM
wrenchguy24
Jul 19, 2011 02:25 PM
GAstreetglide
11
Aug 9, 2008 01:53 PM
profinish
Mar 19, 2008 07:17 PM
vernh59
Jun 10, 2006 11:31 PM
