Bike Won't Start
Old Aug 20, 2015 | 08:10 PM
riod34's Avatar
riod34
3rd Gear
Default Bike Won't Start
I'm a new owner of an 05 Super Glide w/ 11K miles.. I've been riding it several times a week and tonight when I went to start it, everything illuminated for a sec and when I pushed the start button, everything shut down.. I turned the key back and tried again but all that comes on is the odometer..
I'm assuming it's the battery because I don't think it's been changed in 10 years..
The only other issue that may or may not be related is that sometimes it stalls when idling but that's typically when it's just been fired up.
Old Aug 20, 2015 | 08:18 PM
skinman13's Avatar
skinman13
If I were having a problem with a 10 year-old battery, I would be assuming that also...
Old Aug 20, 2015 | 08:22 PM
im's Avatar
im
Confirm battery age, test battery, Change battery.
Advance autoparts runs online coupons...just google coupon advance auto parts.
They have the AGM battery in stock (gel battery).
Some models will need to use the supplied little gold color spacers.
Old Aug 20, 2015 | 08:23 PM
Jonesee's Avatar
Jonesee
Check the voltage at the battery and see where you stand.
Or, take the battery into any parts store or Walmart and have it tested.
I'm guessing your battery is bad.
As for stalling.
1/2 the 2005's were carbed, 1/2 were injected.
If yours is carbed, 1st, congrats, you got a great bike... 2nd, you may need to choke it longer.
A properly tuned, carbed, v-twin does not need any warm up time in the summer. Choke it, start it, leave the choke pulled out and hit the road. My choke will work its way back in gradually.
To tell if it is properly warmed up, reach down and touch the top of the head cover as you ride, if it is getting uncomfortably hot, the bike is well warmed up. If it is, reach up and make sure the choke is all the way back in. (touch the head within a couple of blocks-miles. Not after you have been on the interstate or it will then be way beyond uncomfortably hot...)
If it is injected, it is gas and go. It should not be stalling.
If the battery is totally dead (but it doesn't sound like it is) and it won't accept a charge, it could cause a stall, but that is a stretch. If it were that bad, it wouldn't restart. My guess is get a new battery and all will be good either way.
Now a note. On the 2005 super glides, the batteries Walmart and some auto parts sell can be a touch tall. When you install it, and are bolting it back in place make sure the terminals do not touch the bracket above it or you will short the battery. If you crank it all up tight, there is a good chance you will short it out. I cut an old inner tube and lay it across the top of the battery and terminals to ensure I never short it. Just a helpful hint...
Old Aug 20, 2015 | 08:36 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Pull that old battery out of the bike and do not re install it.
Don`t even bother checking it, just chuck it...
Old Aug 20, 2015 | 08:48 PM
Jonesee's Avatar
Jonesee
If you are pulling it out anyway, and replacing it, you have to return it for a core or disposal fee. Why chuck it?
Take it in, have it tested, verify it is the battery and then make a decision. If it is bad, replace it and save the disposal fee or core charge.
At least give the guy some rational advice.
Old Aug 20, 2015 | 09:36 PM
jaxdwg's Avatar
jaxdwg
And when you put in the new batt. Fill her up with premium and some gas treatment and go ride a tank through it before doing anything about the stall at idle. Gas treatment cleans things up pretty good most of the time and it damn sure won't hurt anything.i have a carbed02 wide glide and, other than rejetting after big bore and cams, I have never had to go through it.
Old Aug 21, 2015 | 04:44 AM
Dan89FLSTC's Avatar
Dan89FLSTC
That was rational advice, it is a ten year old battery. A ten year old battery is not worth spending one minute of his time other than removing it.
Old Aug 21, 2015 | 06:17 AM
Jonesee's Avatar
Jonesee
I'm going to start following you around if just throw stuff away you think is too old.
Figure out what is wrong, and fix that before you start throwing stuff away.
I've commented on here before about Harley riders throwing money at their bikes and repairs without stopping to figure it out first. It is a sign of a poor mechanic.
Like the guy that recently installed a true-track and learned later it was tire pressure like I told him.
I agree, it may be the battery, but at least test it and get the core/disposal fee. By testing it, you learn for sure it is the problem. If, by chance the battery tests good, he will need to be looking at the stator or ignition system.
Know what the problem is before you start spending money. Start cheap and then work your way deeper into your wallet.
Or hell, throw parts away and start replacing them until the bike runs. It's only money...
(I'd rather my money go to gas, oil and rubber)
Old Aug 21, 2015 | 09:19 AM
Daninjax's Avatar
Daninjax
A 10 year old battery needs to be replaced...even if it isn't the cause this time it WILL be soon enough. I'd rather spend the $80-$100 now and replace it rather than have it leave me stranded on the road somewhere. But that's just me.
