winter performance upgrade recommendations
Old Sep 19, 2015 | 08:43 PM
HDDanG's Avatar
HDDanG
4th Gear
Default winter performance upgrade recommendations
I moved from a Honda nighthawk s to a 2010 fxdwg, looking to increase performance and cornering ability on very limited budget. I am a master truck and car wrencher but new to v-twins. thanks
Old Sep 19, 2015 | 08:52 PM
slyedog's Avatar
slyedog
Bike currently stock?
Old Sep 19, 2015 | 08:57 PM
HDDanG's Avatar
HDDanG
4th Gear
Bought it used, what I do know is v & h big radius pipes
Old Sep 19, 2015 | 09:12 PM
Northern B's Avatar
Northern B
High flow air cleaner (if you don't have one already), cams and a good tune, the big radius pipes can actually make decent power.
Old Sep 19, 2015 | 09:14 PM
QC's Avatar
QC
Andrews 48 cams would work real good.
Old Sep 19, 2015 | 09:21 PM
Northern B's Avatar
Northern B
T-Man 555 Torquesters would be another good cam choice.
Old Sep 19, 2015 | 09:36 PM
sharkey's Avatar
sharkey
Cams can wake it up after Stg 1; last 3 sets we've used were S&S E-Z starts. No need for comp releases then, but if you plan on big bore (103) you'll use different pistons & cams than 96 inch.
Old Sep 19, 2015 | 10:30 PM
archergodwin's Avatar
archergodwin
Sputhe Engineering or Tru-Trak engine stabilizers, and a front fork brace.
Not sure how much past a 90 you can go with a wideglide rim, but I'd try a 100 instead.
As for budget... get the manual, and do a vehicle alignment... I swear I don't think that is done when they put these bikes together the first time.
paco12
Oct 10, 2017 12:09 PM
magnum629c
Jul 8, 2013 07:26 PM
Mebeebo
Mar 12, 2010 06:07 AM
1200frk
Apr 13, 2008 08:50 PM
Ed45
Exhaust System Topics
Oct 25, 2007 11:39 AM
