2000 FXDL wire harness
Old Sep 23, 2015 | 12:51 PM
chasenfins's Avatar
chasenfins
Default 2000 FXDL wire harness
Ok, so got new T-bars, front turn signal relocation kit, grips etc. Got the bars installed in about 1.5 hour (first time ever wrenching on a Harley, only Jap bikes and boats and diesels prior too). So that wasn't so bad, but the damn harness deutch plugs are all the way back in the rear fender I'm told. So after researching, I see a lot of people suggest not to cut and either soldering or adding another plug up front to make the job 10 times easier. Any reasons as to why? I saw one post about rust but if you properly install a deutch plug and or solder and heat shrink the wires, why wouldn't you just do that versus removing the back tire, the tank etc?? Anybody done this? Give me some stories.... yea or na
Old Sep 23, 2015 | 06:16 PM
chasenfins's Avatar
chasenfins
Damn, 40 views and no comments? Guess there are just alot of unproven opinions on here.
Old Sep 23, 2015 | 06:27 PM
Harleycruiser's Avatar
Harleycruiser
The plug for the front light/handle bar are under the tank, and yea install a new connector on your new wires.
Old Sep 24, 2015 | 05:46 AM
chasenfins's Avatar
chasenfins
Where under the tank? Only connectors I've found are in the back bone behind the access panel in the rear fender?
beanoboy
Sep 11, 2018 03:12 PM
AlexJamess
Feb 15, 2017 03:21 PM
huey408
Feb 14, 2009 11:04 PM
Pvt.Matter
Mar 20, 2008 06:08 AM
fxdwgcanuck
Feb 26, 2008 05:41 AM
