'15 Dyna frame diameter?
Old Oct 3, 2015 | 07:58 AM
Mchad's Avatar
Mchad
Default '15 Dyna frame diameter?
I want to install a breather catch can and am thinking about mounting it to the frame, so I'll need to order a p-clamp. Anyone know the diameter of the frame?
Old Oct 3, 2015 | 12:38 PM
fskitch's Avatar
fskitch
The down tubes are about 1.5" diameter. I say about because I used my wife's measuring tape with a little metal tab on the end of the tape so could be slightly inaccurate. Use a piece of string or masking tape for exact, measure around (circumference) and divide by pi (3.14). This measurement is off an '07 Dyna frame.
Old Oct 3, 2015 | 01:18 PM
Nitro 54's Avatar
Nitro 54
Measure with a caliper to get the exact width.
Old Oct 3, 2015 | 01:45 PM
O-Town D's Avatar
O-Town D
On my '010 FB, the front downtubes are 1.5" in dia, the lower frame rails 1.25" in dia, but as mentioned you should measure yours for certainty. If you don't have a caliper measuring tool, use an adj wrench and measure the jaw opening. Hope that helps.
Old Oct 3, 2015 | 04:25 PM
Mchad's Avatar
Mchad
Good call on the wrench. I'll confirm with that.
Old Oct 3, 2015 | 07:38 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Use tools you have
Just use your 24" Jumbo Aluminum caliper that you purchased to install your shocks. They are accurate enough to do the job you want to do. They are a nice $10 investment.
Old Oct 4, 2015 | 06:46 AM
Mchad's Avatar
Mchad
****, I forgot I had that! Haha. Thanks Howard.
RSidhu
Jun 29, 2017 01:44 PM
Anty_daniel1
Oct 3, 2016 10:50 PM
joe kustom13
Aug 20, 2012 05:10 PM
F_CPT98
Feb 14, 2010 07:21 AM
rounder
Aug 3, 2008 02:25 PM
