craftsman jack
Old Oct 8, 2015 | 12:01 AM
fxdlx's Avatar
fxdlx
Originally Posted by djack
I dont have problems with my J&S, Im just trying to make the craftsman work with a stand i have.
I see you say you use a 2x4 up front but what about the back that oil pan protector lip hits before the other frame rail.
I jack it up with 3 points of contact. It's steady.
Old Oct 8, 2015 | 01:50 AM
Nikolaiownz's Avatar
Nikolaiownz
i modded the lifters to more wide... fits perfect under my 07 even thoug i got a low profile rear tyre...
Old Oct 8, 2015 | 07:15 AM
hsr's Avatar
hsr
HF's aluminum jack has these add supports. Maybe something like these but with the one side shortened?
Old Oct 8, 2015 | 09:51 AM
djack's Avatar
djack
Yes longhairs mod works but I won't be able
To use my stand, that's why I can't use my J&S
And got the craftsman. The J&S or the nodded craftsman
Are the same width of my stand.
Old Oct 8, 2015 | 09:57 AM
djack's Avatar
djack
As you can see some pivot and adjustment action
Old Oct 8, 2015 | 12:14 PM
Super Glidester's Avatar
Super Glidester
No mean to hijack, but doesn't the Craftsman have adapters for the Dyna sold separately?
Old Oct 8, 2015 | 12:58 PM
djack's Avatar
djack
yep I`ve heard of them, also heard of them coming apart, I just like to make stuff.
Old Oct 8, 2015 | 01:00 PM
djack's Avatar
djack
you know I was kinda thinking that myself but I haven't seen them, I just like to make stuff sometimes
Old Oct 8, 2015 | 06:17 PM
Davdoodles's Avatar
Davdoodles
HD makes simple (though crappy quality and over-priced) adapters for dynas for just this purpose. I bought some on eBay for a few bucks, so I'm not dissatisfied with them. Even then, their design is kind of annoying and makes things tricky to line up (pumping the jack then needing to stick my head under the still-possibly unstable bike to check everything's lined up is not the best/safest engineering solution I've ever seen).
Once in place and hoisted, it is stable.
Probably easy enough to copy/improve upon. The orange part is rubbery plastic, and clips to the frame. The dark bits are hard plastic (ABS possibly), glued to the orange bits.
If I didn't need my lift for my other bikes too I'd probably modify the stand itself by screwing 2x4s (or similar) to it.
EDIT: Oops, just saw Kevinb62's post the the HD part on the previous page. Anyway, will leave this post here as it's got pics and another 'user review'...
http://www.harley-davidson.com/store...ft-adapter-kit
Old Oct 9, 2015 | 02:27 AM
Nikolaiownz
This alu jack is not recommended.. its very unstable with a heavy bike on it..
