Inner primary question
Old Oct 21, 2015 | 07:25 AM
Odin510's Avatar
Odin510
Default Inner primary question
I'm getting ready to remove my inner and outer primary on my 09 street bob for powder coating. I'm assuming I need to replace the oil seal and bearing when I reinstall, and that I'll have to purchase the tool to remove and install the bearing on the inner primary. I already know about getting the inner primary kit, primary gasket, tower gasket, compensator bolt. Can anyone confirm this?
Old Oct 21, 2015 | 08:11 AM
HD Pilot's Avatar
HD Pilot
How many miles on your bike? If you don't have a lot of miles you could pull the seal and just have a good look/feel of the bearing. Inspect the shifter shaft seal while you are there and a great time to clean/lube your jiffy stand.
Old Oct 21, 2015 | 01:09 PM
Odin510's Avatar
Odin510
I have just shy of 12,000 miles. I'm assuming the bearing needs to be removed before powder, right?
Old Oct 21, 2015 | 03:25 PM
HD Pilot's Avatar
HD Pilot
I would ask your pcer, but I would think that they should be able to cover up the bore/bearing. If not I would leave it in to protect the bore area then pop it out afterwards into the trash.
Old Oct 21, 2015 | 07:04 PM
Odin510's Avatar
Odin510
That's a good idea. I was more concerned about the bearings holding up after being baked.
TOMMYBLAZIN
Engine Mechanical Topics
Nov 28, 2017 04:18 PM
Odin510
Powdercoat & Paint
Nov 23, 2015 02:21 PM
RoadHog659
Sep 8, 2011 05:31 PM
PotterBoy
Sep 7, 2011 09:55 PM
abearcarver
EVO
Feb 24, 2009 03:07 PM
