Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Inner primary question
Old Oct 26, 2015 | 05:15 AM
Odin510's Avatar
Odin510
Default Inner primary question
Does the inner primary bearing need to be removed to powder coat the inner primary? Will the heat harm it?
Old Nov 7, 2015 | 02:40 PM
2deuceguy's Avatar
2deuceguy
Curious about this myself as I'm getting ready to do this on a bike I'm working on. I plan to just remove and replace to be on the safe side.
Old Nov 15, 2015 | 07:42 PM
JRK5892's Avatar
JRK5892
100% must be removed, our shop can remove and install a fresh one if needed
Old Nov 18, 2015 | 05:06 AM
grbrown's Avatar
grbrown
Not only is there a risk to the bearing, but also to the paint I suspect, from oil burning off from within the bearing! Isn't there also a seal that will have to come out?
Old Nov 23, 2015 | 02:21 PM
Odin510's Avatar
Odin510
Update...I removed oil seal, retainer ring and pressed out the old bearing. Decided to buy a new bearing. It's a cheap part and figured...why not...I'm already in there. Also, it costs about $100 in gaskets and replacements every single time you remove the inner primary. So I'm replacing any "inspect for wear" parts.
Huggerbugger
Oct 30, 2018 08:03 AM
Odin510
Oct 21, 2015 07:04 PM
Codyyy
EVO
15
Apr 11, 2015 11:45 AM
abearcarver
EVO
Feb 24, 2009 03:07 PM
mike_oh
Feb 7, 2008 12:01 PM
