LED Lighting
Old Oct 22, 2015 | 03:14 PM
Browning1971's Avatar
Browning1971
Stage III
Default LED Lighting
Does anyone know about the Headwinds H4 LED BULB P# 2060-0474, for 2013 Dyna? Is it worth the money, brighter than stock and is it plug and play, meaning how hard to install, and is LED lighting less draw on the charging system? And where is the cheapest place to get it, or another brand better replacement LED bulb?
I cannot afford the HD Day maker, so I was hoping an LED replacement bulb would be better than stock and longer lasting.
As well does anyone recommend the Kuryakyn 7749 LED Halo 5 3/4 trim ring for 2013 Dyna? And is it hard to install? Or is there a better brand anyone knows of that fits the 2013 Dyna FXDB? From what I understand my light is 5 3/4. I would like to find a 5 3/4 LED trim ring in black, if there out there. *This I don't need, but I kind of like if its not hard to install myself.
Any helpful advice appreciated, please let me know if it's not worth spending money on either one? My stock bulb hasn't gone out yet thankfully, but I want to be prepared.
Please send me some web links, thanks.
Old Oct 22, 2015 | 03:25 PM
cggorman's Avatar
cggorman
JW Speaker
Truck-lite
Both make fine LED headlights. I believe the Daymaker is mfg by JW Speaker.
Personally, I would be leery of doing a retrofit bulb in a closed housing like ours. Nowhere for the heat to go. Heat dissipation is a huge issue with lighting-class LEDs. Depending on the diode arrangement and relationship to lens/reflector, the beam may also be far from ideal. I don't have personal experience with LED retrofit headlights, but I've done a few projects with ground-up design for LED fixtures. LEDs radiate light much different than incandescent so the optics and mounting specs are completely different. A QUALITY retrofit would take this into account, but I can't speak to which is good and which is junk.
Might check with the Jeep forum guys, too. I'm thinking the Wranglers use the same headlight as us and those off-road guys like LIGHT.
If you're just looking for more usable light, you may want to look into quality H4 reflector/lens assemblies that fit our housings. I'm not immediately familiar with the beam patterns used in Motorcycles, but I would look into Hella and/or Cibie for possible candidates.
Old Oct 22, 2015 | 03:30 PM
cvaria's Avatar
cvaria
see here:
https://www.hdforums.com/forum/sport...79-led-h4.html
see alse:
https://www.hdforums.com/forum/softa...my-slim-7.html
i have the dk h4 led (because i don't like the thinking behind the daymaker... if it fails on the road you are screwed) in my WG. it throws the red light and 2 codes.
B2136 Low Beam Output Open
B2137 Low Beam Output Shorted High
been using it for about 8 months, no problems
Old Oct 22, 2015 | 08:55 PM
billib1954's Avatar
billib1954
go to amazon, buy 100/55 h4 bulbs and ceramic sockets and forget it. total outlay for 2 bulbs and 2 sockets, about 25.00. these bulbs will melt the stock plastic sockets in a 5 3/4" headlight, no problems in 10 years with a 7". If you're ever on the road and both hi and low burn out, you can go to advance auto for replacements.
RayW88
Nov 21, 2018 04:38 AM
UltraZac
Jul 30, 2017 03:12 PM
Hddyna2012
May 18, 2017 08:25 AM
bikerlaw
Dec 26, 2015 04:13 PM
Browning1971
Oct 23, 2015 11:42 AM
