Electrical problem?
Old Nov 11, 2015 | 10:17 PM
kareengas's Avatar
kareengas
Default Electrical problem?
Got a 1993 FXDWG for a great price as it needs a little TLC. Put in a new battery and it starts and runs great. Got it in storage as I'm in the process of moving. I go over and start it every couple of days. After about a week or of this, it wouldn't start, battery was low. Had a '92 Super and never had a problem letting it set a few days or weeks and having the battery dead. Called the previous owner for thoughts and he said he had the same problem once and found that though he had turned off the switch on the tank, he had left the engine switch on.
Do I need to turn off both switches or does this indicate some problem?
Old Nov 11, 2015 | 10:24 PM
Greezey Rider's Avatar
Greezey Rider
No...Once you turn off the ignition switch it doesn't matter if the run/stop switch is on or off.
You probably have a charging problem or a bad battery.
A cheap multimeter will tell you if the charging system is functioning, if it is then it's probably a weak/bad battery.
Old Nov 12, 2015 | 11:42 AM
nevil's Avatar
nevil
Starting up the bike every couple of days is more harmful than helpful. It will create condensation inside the motor and that's not what you want in there. If you want to run it you need to get on it and ride until it's fully warmed up. At least 20 minutes or so, depending on the outside temps.
Also, by starting and running it for a few minutes will not charge it up enough to make up for the power drained by the starter motor. Get the battery load tested. If you need a new one, get it. And get a battery tender that you leave on while the bike is not being used.
Old Nov 12, 2015 | 12:19 PM
JohnMn's Avatar
JohnMn
nevil's got it right.
Just starting and idleing doesn't run the rpm high enough for a proper charge or warm up the engine enough.
Charge the battery and leave the bike alone until your ready to use it
Old Nov 12, 2015 | 06:20 PM
kareengas's Avatar
kareengas
Appreciate the replies but as stated in the original post, battery is brand new. Metering indicates no apparent shorts to ground. Brought the battery home and fully recharged it but haven't reinstalled. There is no power at storage for the tender. And, like I say, I never had this problem with the '92. I could leave that thing sit for several days or weeks even. Never had to use a tender (not that I probably should have), never had electrical/starting problems.
Old Nov 12, 2015 | 07:56 PM
jaxdwg's Avatar
jaxdwg
What he said
Old Nov 12, 2015 | 09:23 PM
nevil's Avatar
nevil
What kind of battery did you buy? They are not all equal.
If a new battery isn't fully charge when installed, then run down by starting it up and not being ridden, it may not work as it should. I still say you should get it load tested.
Since you don't have power where it's stored, you're probably better off taking it home and putting it on a tender there.
Old Nov 12, 2015 | 09:37 PM
AKFXD's Avatar
AKFXD
I discovered a wire under the seat of my bike that was hot even when the ignition switch was off. It does go through the main 40 amp fuse though. Maybe you could pull the fuse on your bike when you let it sit and see if that stops the battery from going down.
Old Nov 13, 2015 | 12:49 AM
JustOneDean's Avatar
JustOneDean
Starting the engine takes a lot of juice, and it takes a good amount of run time to put that juice back in the battery. Even if it's a new battery, regularly starting the bike but not riding will kill the battery. How long it takes for the battery to no longer have sufficient power to crank the engine depends on how long the bike runs, how many electrical systems the bike has, what temperature the bike's stored in, and what battery it is.
I assume by "the switch on the tank," you mean the key switch, and the "engine switch" is the kill switch. Leaving the kill switch on but the key switch off shouldn't drain power, because if I'm not mistaken, the kill switch comes after the key switch in the circuit. Batteries will lose power over time if they just sit, which may be why the previous owner had the same problem.
All that being said, there could be another electrical problem we're not aware of. Start with the simple things first, though, and put the battery back on the bike now that it's charged. Don't start it unless you plan on riding it, and see if it happens again. If it does and the bike hasn't sat for very long, you'll be looking at three possibilities: something draws excessive power from the battery while it sits, there's a problem with the charging system, or it's just a bad battery.
Also, re-reading my post, I think I should take a shot for every time I wrote "battery." Keep us posted, OP.
Old Nov 13, 2015 | 07:00 AM
skinman13's Avatar
skinman13
If you are not using a multimeter, get one. Set the multimeter to read amps, take off the negative cable from the battery and connect the positive lead of the meter to the cable and the negative lead to the negative terminal of the battery. You should read very little amps to nothing with everything turned off. If your system is draining due to parasitic leaking when it is shut down you will see it. If you are reading anything above say around 100 miliamps, look for a leak, possibly in your voltage regulator.
If you read nothing or very little, then your system is not draining your battery when it is turned off, this indicates that your battery or charging system is AFU.
