Adjusting Stock Bars
Old Jan 12, 2016 | 10:18 AM
johnnyglass's Avatar
johnnyglass
Default Adjusting Stock Bars
Hey guys. Just got my new Dyna this weekend, and I had a question. Is there any precautions I need to take when loosening the allen bolts on the tree to move my bars more forward? Do I need to use a torque wrench when re-tightening things? Is there a part that would keep them from sliding back while riding?
Old Jan 12, 2016 | 10:24 AM
AntonZ1's Avatar
AntonZ1
Take the bars off and ride it. If you can ride it that way a torque wrench is just overkill... no pun intended.
Old Jan 12, 2016 | 10:09 PM
CJeep's Avatar
CJeep
Shouldn't be. On my 07, I adjusted the bars 2 or 3 times. I just retightend by feel, but should have used a tourque wrench I guess. 3000 miles later though, no problems. The bars have some slight splines to help hold in place. Loosen the clamp enough so you don't damage them.
Old Jan 12, 2016 | 11:07 PM
Davdoodles's Avatar
Davdoodles
If they feel snugged down they should be tight enough. The main reason to use a torque wrench would be to avoid over-tightening and stripping a thread.
Some folk use blue loctite (I tend to put a drop one everything as a precaution)...
Old Jan 13, 2016 | 06:51 AM
IrishRebel's Avatar
IrishRebel
I have adjusted mine, turning them upward, hell of a lot better position for me.
Just need to re tighten after riding a bit,as previously stated.
Cheers
Support ur Local BFMC
frog37_
Jul 11, 2019 01:20 PM
apetterez
Oct 28, 2014 07:20 PM
XLsporty
Nov 10, 2011 07:45 AM
SportsterPapa
Dec 25, 2010 12:52 AM
scooterbooter
Oct 12, 2005 11:34 PM
