Help a brother out
Old Feb 7, 2016 | 06:23 AM
Campy Roadie's Avatar
Campy Roadie
First I'd look at the vacuum line running off the petcock to make sure it doesn't have any cracks. That could starve you for fuel at WOT.
Second, I'd look inside the tank and see if you have any tank liner that's flaked off. It could be blocking the screen of the petcock.
If you remove the petcock I would advise having a diaphragm and screen kit on hand. Once one of the old vacuum petcocks it disturbed they leak a lot of the time.
Old Feb 7, 2016 | 09:06 AM
SLV's Avatar
SLV
Saved me the trouble. I was going to recommend the same two checks. I'm betting on a pinched vacuum line or tank not venting. Debris in the peacock or floating in your bowl is the next thing.
Old Feb 7, 2016 | 10:35 AM
Campy Roadie
Yep I agree. The rubber diaphragm in the pet **** could have crack in it as well.
Old Feb 7, 2016 | 11:10 AM
14GuineaPig's Avatar
14GuineaPig
Can you pull to red line in the first 4 gears?
Old Feb 7, 2016 | 01:35 PM
gartec81's Avatar
gartec81
Clean positive and negative terminals on battery. Had a bike that above 60 terminals were not making proper contact and bike would fall on its face
Old Feb 8, 2016 | 05:08 PM
apetterez's Avatar
apetterez
I have a gravity pingel pet **** no vacum line.
And i will check the liner and float bowls next. I feel it might be a manifold leak. I lost a beeather bolt that holds my valoscity stack and the other one backed off. Maybe the carb rattled to much once loose and tore the gaskets.
Fusion777
Apr 9, 2018 07:25 PM
Sanford
Sep 17, 2012 08:26 PM
evolover
Oct 23, 2009 05:57 AM
derose
Welcome Area Only
18
Sep 28, 2009 09:21 AM
SkonesMickLoud
Jul 13, 2006 09:25 PM
