DOT break fluid
Old Feb 15, 2016 | 09:34 PM
cvaria's Avatar
cvaria
Originally Posted by JohnMn
^↑ Do that ↑^
You can view your bikes owners manual by logging in here.
https://www.harley-davidson.com/cont...rs-manual.html
As several have already said you don't wanna mix different grades.
i checked for his year, it's not there, 2005 is the cut off. that's not cool. there are other ways but, the forum mods don't like people posting that kinda stuff.
Originally Posted by racer11
Thanks guys for the input and suggestions,,,,,I stopped at Oriley on the way home and bought a small container of the DOT 5,, pricey stuff for sure. I don't see why the system would have a need for that type of fluid but I for sure need to use what the factory designed to be in it.
just give your local dealer a ring. that's a freebie answer they'll give you. it think someone above confirmed your bike was dot 5 though.
Old Feb 16, 2016 | 10:46 AM
multihdrdr's Avatar
multihdrdr
The reason you need it is because you're already running it.
If you "kit" your M/Cs and Cals, replace your hoses, You too can run Dot 4
Don't forget to change your M/C covers fluid identifier...for the next guy
Old Feb 16, 2016 | 05:07 PM
Racqueteer9's Avatar
Racqueteer9
DOT5 is less hygroscopic so it doesn't absorb water as easily as DOT3 or 4. Or maybe HD got a smoking deal on different gasket material?
Boat Tail
General Topics/Tech Tips
17
Oct 23, 2019 04:16 AM
98hotrodfatboy
EVO
34
Jul 12, 2019 07:07 PM
89FLHTC
EVO
Nov 16, 2015 06:47 PM
Taterdog
Mar 29, 2010 06:00 AM
jonnyrotton
Dec 22, 2007 10:42 AM
