driving me nuts -howling sound
Old Mar 10, 2016 | 12:34 AM
Smarsmar101's Avatar
Smarsmar101
It's the belt, I had the same EXACT problem right after my first service.
Took it back in and had them loosen the belt @slightly" and it went away. EASY
Old Mar 10, 2016 | 12:36 AM
harlot's Avatar
harlot
I actually just used a belt tension tool to measure and the tension is spot on
it is a new bike just under 1500 miles
Old Mar 10, 2016 | 12:50 AM
Smarsmar101
I'm telling u, it's the belt. Mine was 1023k and adjusted belt at service and had the howl. Lessened it up abut and boom. Fixed. Looser is better anyway.
Old Mar 10, 2016 | 07:38 AM
harlot's Avatar
harlot
UPDATES
check the spec of the belt, it is correct.
Upon closer listening it seems the whirring or howling could be from the transmission, is there any reason to now worry?
Old Mar 10, 2016 | 07:48 AM
AKFXD's Avatar
AKFXD
Originally Posted by harlot
UPDATES
When you hear it the loudest, if you pull in the clutch, does it stop?
Old Mar 10, 2016 | 08:22 AM
Red Dragons's Avatar
Red Dragons
Howling sounds can definitely come from the primary if the chain tension is off or it's rubbing against something inside the case. I would open the primary.
Old Mar 10, 2016 | 09:35 AM
WRKD4ITFLHX2008's Avatar
WRKD4ITFLHX2008
UPDATES
Does it sound like a Jetson spaceship lol if so check crank tolerance
Old Mar 10, 2016 | 09:51 AM
IdahoHacker's Avatar
IdahoHacker
Had the same noise in my '14 Dyna. Scrubbed the belt clean and it stopped.
Old Mar 10, 2016 | 05:22 PM
stevmac1's Avatar
stevmac1
Originally Posted by TriGeezer
Does the howling stop when your OL isn't riding on the back?
Beat me to it!!!!!!!
I used to say that to my OL when she drove her Jeep.
Old Mar 10, 2016 | 07:44 PM
harlot's Avatar
harlot
Yes it does! Please tell me u have a cure
