Front fork sliders
Old Mar 16, 2016 | 12:22 PM
mock24v's Avatar
mock24v
Default Front fork sliders
I just bought new fork sliders for my 2007 street bob and I was wondering what steps do I have to do to replace them?. And can I reuse all the seals? I know I'll have to replace the fluid. Any help would be great
Old Mar 16, 2016 | 12:44 PM
Reindeer's Avatar
Reindeer
You'll want to replace the seals at the top end of the slider. If I remember right there's an oil seal that fits inside the top of the slider, and a dust seal on top of that under the cap. And maybe a crush washer at the bottom? Was a couple years ago when I did mine.
Not a terrible job, as I recall the worst parts were getting the bolts loose on the bottom of the slider, and reinstalling the top spring caps.
Old Mar 16, 2016 | 01:10 PM
cvaria's Avatar
cvaria
Originally Posted by Reindeer
replace it all
agreed
the kit is 35 a slider hd p/n: 49379-09. or you could use an aftermarket kit. you could do just the oil seals (19 on diagram below) on the cheap for about $6 (google: 49mm oil seals fork )
ref:http://partsfinder.onlinemicrofiche....TEERING%20STEM
inside the fork you'll find:
just pulled it off on my sporty and will be doing again in a few weeks on the dyna.
https://www.hdforums.com/forum/sport...l#post14856797
delboy:
i didn't follow his seal install method. i cleaned my uppers well then used a pvc pipe and a rubber mallet too pound it into place. plenty of vids out there to help you
***loosen bottom bolt (31 in diagram) before removing forks from trees (12mm hex, long/deep) if you can. total PIA
have fun
Old Mar 16, 2016 | 09:59 PM
archergodwin's Avatar
archergodwin
Get all new seals... in a seal kit.. doesn't have to be HD. The kits will come will all you'll need, including the copper 'crush' washer for the bottom bolt.
Old Mar 17, 2016 | 08:49 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Fork seals from HD are $20. Next to blinker lenses, those are the cheapest things in the building!
Brad Stillman
General Topics/Tech Tips
Dec 18, 2015 10:01 AM
MZBuckeye
Jul 3, 2012 11:01 AM
karlkcfi
Apr 6, 2012 08:08 AM
karlkcfi
Apr 1, 2012 03:42 PM
DWhite
Apr 22, 2008 03:52 PM
