Fork Seals
Old Dec 17, 2015 | 12:18 PM
Brad Stillman's Avatar
Brad Stillman
Stage I
Default Fork Seals
Have a 2007 Street Glide. Getting ready to do 50k on forks. Have the FSM, but doesn't really say what to replace. I want to have replacement parts on hand. Which seals/ O rings typically need replacing at 50k?
Thanks.
Old Dec 17, 2015 | 01:24 PM
chromelens's Avatar
chromelens
Here is a list of the factory parts you will need for a full rebuild.
45405-75a Damper Tube Bolt x2
45875-84a Fork Seal x2
Two quarts of Type E fork oil
If the slider bushings are in good shape you will not need to replace, but for the cost and being you are already in the forks I would just replace them is they look worn.
45866-84 Slider bushing x2
4940-84 Slider bushing x2
I would also suggest a progressive spring upgrade or something similar. You will also need a fork seal driver and a long allen socket to remove the damper bolt. Hope this helps.
Old Dec 17, 2015 | 01:42 PM
Roadblock_MN's Avatar
Roadblock_MN
That sounds close to what I did. I actually called a dealership and asked them what they typically replace on a fork rebuild. Then I ordered everything online with the exception of the oil, I used the Amsoil racing oil which is a heavier weight oil.
Old Dec 18, 2015 | 10:01 AM
dfwhockey17's Avatar
dfwhockey17
Do the bushings while you are there, they are cheap insurance against another tear down and rebuild in a few miles...
mock24v
Mar 17, 2016 08:49 AM
HDJEFF
Apr 26, 2008 07:00 PM
EastSideBikerTrash
Apr 24, 2008 08:07 AM
57ironhead
Ironhead
Aug 24, 2007 12:12 AM
Sincecrazy
Aug 27, 2005 11:09 AM
