General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
The solenoids are located in the heads under the rocker boxes, the connectors should be under the fuel tank just over the intake.
You'd have to really soak down your bike in order to get them wet, I don't see how you could "bump" them.
Thanks, that helps a lot. Ill go out and check the connections. If the ACR or ACR's are bad, guess Ill have to let the dealer replace. Sounds a little out of my league since I'd have to disassemble the top of the bike to get to them.
