Engine Code Help/Advice
Old Jul 7, 2009 | 08:39 AM
Wooglint's Avatar
Wooglint
Default Engine Code Help/Advice
Last night when I was goofing around with my bike (08 Fatbob) in the garage when I noticed that the check engine light was coming on for ten seconds after I started the bike. So I pulled the codes. Here is what I got:
P0261 Front Injector Open/Low EFI
P0263 Rear Injeactor Open/Low EFI
P1003 System relay Contacts Open EFI
I cleared the codes and restarted the bike and let it run for a while. The codes didn't come back and the bike seems to be running fine.
Do any of you have any insight into these codes? Does the bike need to go in for service? I'm suppose to head out for a ride on Friday for the weekend and that would suck.
Any help would be appreciated. Thanks.
Old Jul 7, 2009 | 09:55 AM
JRK5892's Avatar
JRK5892
if the codes do not come back on i would not worry about it, could be just a oops in the tuner as that controls those injectors... if it stays off you are fine... if it comes back i would adress it then
Old Jul 8, 2009 | 03:54 PM
YourOldDog's Avatar
YourOldDog
Has the bike been laying on it's side that you are aware of? I dropped mine in some gravel and got check engine light. I don't remember what the codes were but they haven't been back. I've decided not to lay it on it's side anymore.
Old Jul 9, 2009 | 03:30 PM
Wooglint's Avatar
Wooglint
As far as I know the bike as remained right side up. But I agree that keeping it that way is a good thing.
SPARKY01
May 14, 2011 08:25 AM
wjl24
EVO
Oct 21, 2009 07:22 AM
paulies 07
Nov 2, 2008 03:07 PM
GreighWolf
Jan 16, 2007 12:44 AM
Scout
14
Jul 28, 2005 12:16 PM
