Detachable hardware compatibility
Old Mar 24, 2016 | 06:54 PM
dlporter's Avatar
dlporter
Default Detachable hardware compatibility
I have a 2015 Street Bob and want to put a detachable sissy bar on it. I plan on using turn signal relo kit 53968-06C to keep my turn signals on the fender struts. My question is regarding the license plate bracket. With this turn signal kit the stock license plate bracket won't work, but I want to keep a side mount setup to preserve the look of the chopped fender. I would like to use this kit, but I am concerned that the rotating clamp on the sissy bar my hit this mount. Nothing in the P&A catalog says this combination won't work, but my dealer parts and service guys couldn't confirm that it would work either. Has anybody here on the forum tried this setup and can confirm if it will work or not?
Old Mar 24, 2016 | 10:37 PM
ajk511's Avatar
ajk511
http://www.dkcustomproducts.com/License-Plate-Bracket-Vertical-Mount-DK-LPR-VER.htm
Old Mar 25, 2016 | 12:51 PM
blueangel73's Avatar
blueangel73
dlporter, theat mount you linked you shouldn't have any issues with, it mounts between the fender and the strut. So that part you are worried about interfering with your detach claps will be matted up under the strut.
http://www.harley-davidson.com/app-c...ts/-J04703.PDF
bigbadpoppa
Apr 5, 2016 12:44 PM
Port City Hog
Mar 4, 2011 02:10 PM
lunloon
Jul 10, 2009 03:37 AM
Big Nach
Jan 14, 2009 07:41 PM
nkauf21
Apr 20, 2007 09:13 PM
