Rear signal light relocation kit???
Old Jan 14, 2009 | 03:46 PM
Big Nach's Avatar
Big Nach
Stage IV
Default Rear signal light relocation kit???
I'm in a bit of a pickle. I have a 2006 Dyna Super Glide Custom. I have put on a side mount licenses plate that looks sweet! I would now like to add the detachable sissy bar but i need to relocate the rear signals first. HD's relocation kit mounts them to the license plate bracket but i dont have one now since i have the side mount.
Any ideas?
Old Jan 14, 2009 | 04:01 PM
07bobber's Avatar
07bobber
I have the det sissy bar setup your looking for look in my album to see what it looks like. Im sure someone will post the part number...
Old Jan 14, 2009 | 04:03 PM
jmpancoast's Avatar
jmpancoast
Harley makes what they call a rear signal relocation kit, but it is really a signal remounting kit. There are two holes on the rear of the strut which the signal use. One hole is for the mounting bolt, the other is to run the wires from the signal to the underside of the fender.
The remount kit moves the signals back only using the rear hole. It provides mounting stalks which are hollow. The wiring runs through the hollow mounting stalks to the underside of the fender. The stalks ave a poly bushing on the outside used as the rear mounting point for the detachable side plates.
The part number for this docking hardware/remount kit should be listed on Harley's website under the listing for for the detachable sideplates for your model.
http://www.harley-davidson.com/pna/p...bmLocale=en_US
Old Jan 14, 2009 | 04:04 PM
JRK5892's Avatar
JRK5892
man use the search function on the top of the page.. there are a TON of options out there, i see that this is your first post, if you scroll thought he postings this went around about a week ago... lots of good info it in... glad to have you with us man!
Old Jan 14, 2009 | 04:25 PM
Big Nach's Avatar
Big Nach
Stage IV
Thanks to all of you. i appriciate the quick responses.
Old Jan 14, 2009 | 04:36 PM
JRK5892's Avatar
JRK5892
welcome to the mad house!!!
Old Jan 14, 2009 | 06:21 PM
Wireguided's Avatar
Wireguided
jmpancoast has a nice flhr set up that is another option..
Jrk has a good point as well many of us have a re-locate post try the search it is very helpful........
Old Jan 14, 2009 | 06:34 PM
dpriest's Avatar
dpriest
how bout here
Old Jan 14, 2009 | 06:43 PM
OhioSkully's Avatar
OhioSkully
Yes the harley kit gives you the bolts with thru hole for the wiring and look pretty good price is like $36 bucks just checked on it yesterday for myself.
Old Jan 14, 2009 | 06:58 PM
rockon's Avatar
rockon
Had a bracket made for mine...mounted LEDs to the shock bolt.
