Dyna S Lounge: FXDL-S
Old Jun 12, 2017 | 06:00 PM
  #231
Buddy Shagmore's Avatar
Buddy Shagmore
Question: Are there any differences between the '16 & '17 models? Were there any issues with the '16 models that were fixed on the '17s? I might buy a leftover '16 model...should I expect a discount? Thanks for any help.
Old Jun 12, 2017 | 06:34 PM
  #232
17FiXxXeR75's Avatar
17FiXxXeR75
No difference. HD just charged more in '17.
Old Jun 12, 2017 | 06:36 PM
  #233
rbdub474's Avatar
rbdub474
I asked the same thing when I bought mine in September. I was told the only difference was the MSRP was raised for 2017. So I got a 2016. I was able to get a good deal, but that is because it's not a real popular model in my area. Baggers and Sportsters are about all you see here. Being in CA I think you might have a harder time getting a screaming deal even on a 2016.
There has been an ECM update that might already be programmed on a really fresh built 2017, but it is easily fixed by a reflash at the dealership if you go with a 2016.
Old Jun 14, 2017 | 09:30 AM
  #234
thisisagame24's Avatar
thisisagame24
Has any one figured a way to vent the crankcase gazes to atmosphere while still using the stock intake?
Old Jun 14, 2017 | 09:39 AM
  #235
17FiXxXeR75
Like this?
http://www.dkcustomproducts.com/All-Twin-Cam-Engines_c76.htm
Old Jun 14, 2017 | 12:22 PM
  #236
thisisagame24
The link isn't working
Old Jun 14, 2017 | 12:54 PM
  #237
17FiXxXeR75
Did you try to copy & paste it? It works on my end.
If not just go to the DK website and look in the Air Cleaner section.
Old Jun 14, 2017 | 03:42 PM
  #238
thisisagame24
I've seen their stuff and love it. Had a lot of my sportster. But wasn't sure if anyone had gotten something to work with the stock intake system of the LR-S
Old Jun 15, 2017 | 05:13 AM
  #239
geminisdividing's Avatar
geminisdividing
3rd Gear
Default FXDLS specs question
do the stock 110 heads on the 2017 FXDLS have high lift valve springs?
also the throttle body 50 or 58 mm stock? also anyone else get the recall letter from Harley MoCo about the tune re-flash? for better start ups and the compression release blah blah blah? TIA
Old Jun 15, 2017 | 07:18 AM
  #240
jackafrica's Avatar
jackafrica
high lift valve springs, yes.
50mm tb
there's a whole thread on here about the 621 base cal.
