Tranny oil from factory?!
Old Mar 26, 2016 | 09:06 PM
Ruger223's Avatar
Ruger223
6th Gear
Default Tranny oil from factory?!
I have a 2016 wide glide...tranny fluid is a little low after changing the cover to chrome. I don't want to mix oils so what oil did the tranny come with from the factory? Syn3? He360?
Thanks!
Old Mar 26, 2016 | 10:25 PM
JohnMn's Avatar
JohnMn
It only holds a quart, why not pull the plug, drain it all and put in whatever you want?
Old Mar 26, 2016 | 11:41 PM
JustOneDean's Avatar
JustOneDean
Probably Formula+. Nothing wrong with mixing oils, though.
Old Mar 27, 2016 | 03:01 AM
TinCupChalice's Avatar
TinCupChalice
Unless there's been some drastic changes from '13 to '16 your Wide Glide transmission takes, per the owners manual, approximately 28 ounces of fluid. On my '13 it's right around 29 ounces.
Factory fill on my '13 in primary and transmission was Formula+. Nasty stuff and it was dumped on day 1 new off the dealers floor, lots of better options for the transmission are available. If you've already lost fluid due to the cover change it's a great opportunity to change out the Formula+ to a proper gear lube suited to the task such as Redline V-Twin Transmission fluid w/shockproof or Mobil 1 synthetic gear lube...
JustinReed86
Jun 21, 2019 12:21 PM
Ruger223
Oil Archive (no new posts)
Mar 27, 2016 10:09 AM
BobbyVera
Sep 14, 2013 08:45 PM
jaysonL
19
Aug 13, 2010 03:56 PM
dmanyeah
Jul 12, 2006 07:40 PM
