Wheel Spacers
Old Mar 29, 2016 | 06:44 AM
widerider96's Avatar
widerider96
Default Wheel Spacers
Hi all,
On a 2011 wideglide are the rear wheel/axle spacers the same size and which side/way do they orientate?
Just had tyre change and it is definitely now to the left is the rear wheel, brake rotor not centered and the drive belt hugging right hand side of the pulley.
Kindest Regards
Richard
Old Mar 29, 2016 | 06:55 AM
Scrmnvtwins's Avatar
Scrmnvtwins
Caliper and rotor misalignment is a good indication but I am no Dyna expert. Can you see or measure a difference? If yes then disassemble and reassemble with change.
both my 81FX and 89 FXR had different lengths for each side but I cannot say about a newer Dyna
Old Mar 29, 2016 | 08:26 AM
archergodwin's Avatar
archergodwin
The spacers are different, and it looks like the longer one needs to go on the pulley side.
Old Mar 29, 2016 | 09:51 AM
EC1956's Avatar
EC1956
http://www.stcharlesharleydavidson.c...c%7eLACED%5cGP
Old Mar 29, 2016 | 11:14 AM
widerider96
Thanks all yes it is measureable/noticeable - 3mm - I will check which is on which side.
Got similar issue on front after a powdercoating hub and relaceing but i know those spacers are correctly mounted. i am wondering on front if the bearings are not back in properly or fitted to wrong side (if it makes a difference) as its 1/4" to rhs and again rotor out of centre.
Much appreciated
Old Mar 29, 2016 | 11:31 AM
Scrmnvtwins
Wheel bearings and spacers have a specific installation with the 1st bearing installed to the correct depth followed by pulling the other bearing opposite side against the spacer to the 1st installed. If you do not have this information, look on the H-D website for custom wheel your application then note the correct wheel spacer specified. Search for H-D installation instruction that kit and it will prescribe installation.
Old Mar 29, 2016 | 05:51 PM
AKFXD's Avatar
AKFXD
There is a big difference.
Pulley side. (without pulley)
Brake side.
When you had the front hub powder coated, did they unlace the hub from the rim and then relace it?
Edit: I see it was relaced. It could have been relaced off center.
Old Mar 29, 2016 | 08:22 PM
archergodwin
Originally Posted by AKFXD
When you had the front hub powder coated, did the unlace the hub from the rim and then relace it?
If the rotor is not aligned with the calipers, (providing it's the same hubyou sent that you got back), it's not because of the lacing job. Most likely the bearings not seated in the proper sequence as was mentioned.
Old Mar 29, 2016 | 08:40 PM
AKFXD's Avatar
AKFXD
I agree with that.
If you put the front wheel on without the caliper attached to the slider, and the rotor is too close to or too far away from the slider for the caliper to bolt back on, you might have a bearing install problem.
Old Mar 29, 2016 | 10:45 PM
hetkehog's Avatar
hetkehog
hummm bout all I can say about that thread
