Turn signal inop!
Old Apr 3, 2016 | 07:59 PM
Doug W's Avatar
Doug W
Default Turn signal inop!
Sheesh! Brand new 2016 Wide Glide. Got 60 miles on it, and suddenly the left front turn signal is inop; and it isn't the bulb..
Old Apr 3, 2016 | 08:03 PM
RANGER73's Avatar
RANGER73
Take it back to the dealer tomorrow.
Old Apr 3, 2016 | 08:26 PM
Doug W's Avatar
Doug W
Closed Mondays. I'm swamped with work anyway; I'll try to get there sometime this week, though.
Hope this isn't a harbinger of things to come..
Old Apr 3, 2016 | 08:33 PM
QC's Avatar
QC
Sucks, dude. After they get it sorted, call Custom Dynamics and get some LEDs in there.
Old Apr 4, 2016 | 05:20 PM
RANGER73's Avatar
RANGER73
Bike is new, don't screw with it.
Old Apr 4, 2016 | 05:48 PM
Doug W's Avatar
Doug W
When I first removed the bulb and saw all the grease on the contacts, I wiped it off and cleaned out the receptacle a bit, with a rag; didn't make a difference.
Then a friend mentioned the tendency of the factory to load too much grease in there, and I took the bulb back out, wiped off the contacts again, and this time took some q-tips and alcohol to the receptacle; works fine now.
Old Apr 4, 2016 | 06:46 PM
RANGER73's Avatar
RANGER73
Put a little back, it's dielectric grease and prevents water corrosion and oxidation.
Old Apr 4, 2016 | 06:56 PM
Suede Blue Man's Avatar
Suede Blue Man
I read somewhere once that can-bus doesn't tolerate as much dielectric grease as non-can-bus.
Article said it interferes with the signals. That's what I read anyway.
Old Apr 4, 2016 | 07:06 PM
Doug W's Avatar
Doug W
Thanks!
Yeah, I figured it was dielectric; I just wanted the pleasure of seeing the bulb light up again. I'll put something on the contacts soon.
Old Apr 5, 2016 | 09:40 AM
RANGER73's Avatar
RANGER73
Can-Bus should have nothing to do with it. It should still be a metal to metal contact. The grease just keeps the water from contacting the metal parts.
