How ro replace battery 2010 dyna
Old Apr 5, 2016 | 05:25 PM
Chicago Ken's Avatar
Chicago Ken
Default How ro replace battery 2010 dyna
What to I need to do to change my battery in a 2010 Fat Bob.
The bike has the factory alarm.
Thanks. I tried YouTube but had no luck.
Old Apr 5, 2016 | 07:37 PM
mirrmu's Avatar
mirrmu
Disconnect it, remove and put new one in
Old Apr 5, 2016 | 07:57 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
April Fools Day was 4 days ago.
In case you're serious, disconnect the Neg. terminal then the right.
Pull battery
Connect the Neg. terminal then the right.
Old Apr 5, 2016 | 08:43 PM
cvaria's Avatar
cvaria
https://www.harley-davidson.com/en_U...na/file-7.comp
Old Apr 5, 2016 | 08:56 PM
nevil's Avatar
nevil
Don't forget the first step- remove the battery cover.
Old Apr 6, 2016 | 03:28 AM
Davdoodles's Avatar
Davdoodles
Keep your alarm fob next to the bike or the alarm will go batshit when you disconnect the batt leads (thinking the bik'es being jacked), but otherwise it's easy.
From memory, you'll need a T5(?) Torx driver bit for the sidecover bolt (hidden slightly at the bottom of the batt cover).
Don't let Batt leads touch any metal/frame etc until both are clear of the Batt.
Old Apr 6, 2016 | 06:39 AM
jmeiers's Avatar
jmeiers
Is this seriously a question?
Old Apr 6, 2016 | 09:24 AM
JohnMn's Avatar
JohnMn
What? You can't.
When the battery is done the bike is wore out. You have to throw it away and buy a new one.
Please dispose of your bike properly, just throwing it in the trash is wrong, you should bring it to a recycle center.
Old Apr 6, 2016 | 11:36 AM
AKFXD's Avatar
AKFXD
Good answer.
Old Apr 6, 2016 | 01:07 PM
Chicago Ken
Thanks for the honest replies.
I wasn't sure if I would mess up alarm if I just yanked it out. That's why I asked to make sure before doing.
