super glide question
Old Apr 9, 2016 | 05:27 PM
papascrump's Avatar
papascrump
1st Gear
Default super glide question
Quick question regarding my '09 super glide custom. The odometer is showing "diag", i have enough common sense to figure out it means diagnostic. My question is whether or not it's telling me something is wrong or just to get my standard maintenance. Im at 15,400 miles if that helps with an answer. Thanks!
Old Apr 9, 2016 | 06:29 PM
103luckygreenDude's Avatar
103luckygreenDude
I have not had this problem, but I would check everything that was at my "pay grade". You might find simple problem that you can fix. If not proceed to a mechanic that can diagnose it.
Old Apr 10, 2016 | 08:43 AM
archergodwin's Avatar
archergodwin
If it is showing that everytime you power up... your trip button on your side console is shorted, or that wire is pinched/grounded somewhere.
Any work on your console lately?
To put your system into 'DIAG' mode, you press your trip/reset button, and then power the bike on with your main switch (with your run switch on too)
Old Apr 10, 2016 | 11:44 AM
papascrump's Avatar
papascrump
1st Gear
I recently replaced the battery so that may have something to do with the diag message. Ill check it out and make sure everything is connected properly again. Thanks for the help!
umassminuteman89
Jul 12, 2019 08:05 AM
SharkBite
Electrical/Lighting/Alarm
13
Feb 7, 2017 12:34 PM
doc308
Oct 16, 2013 08:41 PM
7Sixpack7
Apr 23, 2012 07:38 PM
street bob 59
Jul 20, 2010 07:21 PM
