No, it's not done to keep them from failing prematurely. Have you ever replaced wheel bearings on a trailer? They are set up with clearance/lash, and are subjected to much harsher use than our headstock bearings. Nor are bearings in general set up with preload very often. Zero or negative clearance interferes with maintaining a lubricant film.
Tapered roller bearings operate ideally at 0 lash, no clearance or preload. That's not always achieveable. There are also other factors to consider such as heat, operational clearance, and stiffness.
I emphasize stiffness because that is the primary reason headstock bearings are preloaded. A trailer bearing is not the same operational environment as a neck bearing in the least.
However, the stiffness of the neck of a motorcycle and accompanying front end is high importance. You can't have any play there for the chassis and suspension to work as intended. They are designed to be a stiff unit so that the frame and suspension take up all the forces in a predictable, smooth way. That is why the neck bearings are set with a small preload.
I have motor mount stabilizers front and rear.
Done the steering head bearings.
Adjusted upper motor mount to make the rear wheel plumb .
And have new tires.
Tightened spokes and balanced wheels.
Wheel bearings seem ok when on a center lift...
And the wobble is worse than when I started.
Bout to sell it.
Do you have saddlebags? Are they possibly sitting too far back, or unsupported possibly?
I'm seeing lots of death wobbles reported because of that...
Sort of like having your passenger sitting too far back, they will split your center of gravity an cause all these symptoms. Not to mention the harmonic flapping unseen to the naked eye that aggravates the situation further.
Two completely different bearing applications. Neck bearings aren't rotated 360 degrees thousands of times in one use like trailer wheel bearings; or ever for that matter. The Harley service manual outlines the correct procedure very plainly. My life got a lot easier when I finally figured out I didn't know what I didn't know.
I have never had this sort of issue with my '12 FXDC. Several years ago I changed out my cheapo stock H-D wheel bearings for brand name (Fafnir/Timken) pieces due to a slight wheel bobble at some speeds. After that, everything is rock-solid. I do have a Sputhe stabilizer, front and rear, Ohlins +2inch shocks and Racetech emulators.
I can lay mine down low in tight curves. Had to install V&H Upsweep for exhaust clearance. No wobbling.
Well bearings are set up completely different. The load and heat require a loose fit or they can tighten and overheat.
Neck bearings are set up more like pinion bearings , light preload.
Neck bearings set up with preload and are not going to fail because of preload, more likely to be damaged from being too loose.
Without taking this thread sideways, I just want to note I just experienced the death wobble. At 70 mph on sweeping curves using a HD windshield caused this. The wind going around the windshield as I aggressively lean the bike wobbles my front end like mad. I wont be using a windshield ever again besides straight line hwy rides.
