2002 wide glide brakes
Old Apr 22, 2016 | 10:20 PM
hetkehog's Avatar
hetkehog
Default 2002 wide glide brakes
Im can't get my brakes bled. Thought it was the master cylinder. Still nothing. I can not pull fluid from the master cylinder. I have a vacuum pump, put it on the bleeder. Nothing. Actually pulled the line off the master and put it in the jug of fluid. I pulled it all out of the bottle. Hooked the line back up to the master, nothing. Both master cylinders the same way. I bench bled the master, or thought I did. Maybe doing something wrong. This is the very first brake system I am stumped on. And I've done a lot of them. Any ideas?
Old Apr 22, 2016 | 10:21 PM
hetkehog's Avatar
hetkehog
And its the front brake by the way.
Old Apr 22, 2016 | 10:27 PM
QC's Avatar
QC
You get nothing when you pump the brake lever?
Old Apr 22, 2016 | 10:28 PM
hetkehog's Avatar
hetkehog
Yes nothing. With with master. The original one or the new one.
Old Apr 22, 2016 | 10:38 PM
QC's Avatar
QC
Start from the beginning and re-bench bleed it. You're using the proper fluid?
Old Apr 22, 2016 | 10:39 PM
hetkehog's Avatar
hetkehog
Dot 5
Old Apr 22, 2016 | 10:41 PM
QC's Avatar
QC
I assume that is what is specified on the cover.
If you unhook the line from the banjo down at the caliper, do you get anything?
Old Apr 22, 2016 | 10:47 PM
hetkehog's Avatar
hetkehog
No. Nothing. Just seams weird both master cylinders would do exactly the same
Old Apr 22, 2016 | 10:48 PM
hetkehog's Avatar
hetkehog
Like I said. I can draw fluid from the line at the master cylinder but nothing from the master after I hook up the line.
Old Apr 22, 2016 | 10:50 PM
QC's Avatar
QC
Banjo bolt plugged? I'm stumped.
