Lift question
Old Apr 25, 2016 | 08:12 PM
kontiki's Avatar
kontiki
Originally Posted by dpoll995
Looks like the basic lift mod won't work with my bike. I'm gonna have to get longer bolts and bigger spacers to get it a little wider. Also the red frame arms of the lift hit my oil pan and part of the kick stand so will probably have to put a board under one of the wheels. What kind of bolts did you guys use? I just grabbed the regular bolts at Home Depot, are the strong enough?
I ordered some metric bolts the same size as the stock metric bolts except longer. That way I didn't need to drill the holes out any bigger. I bought some extra washers and stacked three or four to act as spacers to give me about half an inch extra spread to the lift bars. I also notched the front lower bar where the jiffy stand spring attachment nub was preventing from sliding it under all the way.
hands between the lift bars
Old Apr 26, 2016 | 08:53 AM
Reindeer's Avatar
Reindeer
Make sure they're grade 8 or the metric equivalent, then you should be fine.
Old Apr 27, 2016 | 02:39 PM
DynaChass's Avatar
DynaChass
6th Gear
I've just completed the lift mod but it seems the rear pad will still be on the oil pan. Is the pad supposed to miss the pan all together, or is it fine that it will be resting on it as long as it's sturdy and strapped down?
Old Apr 27, 2016 | 02:59 PM
TinCupChalice's Avatar
TinCupChalice
Not exactly something I'd do
You're going to need to use additional spacers to get more distance between the lift pads; you lift on that pan and you'll not be very happy with yourself.
I did these shenanigans on several cheap lifts for my Dyna's; I finally wised up and bought a J&S lift. The two smartest things I've bought for my new Dyna is a Power Vision and a J&S lift...
Old Apr 27, 2016 | 07:41 PM
NorthWestern's Avatar
NorthWestern
I believe you, and just did both
Old Apr 27, 2016 | 08:45 PM
tnriverluver's Avatar
tnriverluver
I recently modified my red Craftsman i've owned for 15 years, but had to add some washers to space the supports out further than what is shown on the Youtube video to get it to work and clear my kickstand on my 2011 FXDC. Other than that it works like a charm and will still work on my wifes 600 VLX and a Vulcan 750.
Old Apr 28, 2016 | 06:30 PM
dpoll995's Avatar
dpoll995
Just finished modding mine. Had to use 7in bolts and 1.5in spacers and also did some grinding on the 2 brackets that the jack pin pushes up on. The grinding of brackets lets the jack go a little lower, I still have to push it down a little with my foot as I slide it under the bike but at least I don't have to mess with driving it on some wood blocks.
Old Apr 28, 2016 | 09:53 PM
hAkron's Avatar
hAkron
^^This guy gets it!
I had the red Sears Jack and the rubber things you pop on the frame that Harley sells, and that's an ok setup, but the Sears Jack wouldn't fit under my Street Glide, so I bought a Harbor Freight lift that seemed like it was well built, but lowering the bike was way too scary fast so I bought a J&S lift, and it works great, on BOTH bikes. I still use the Sears lift and the frame bumper things to get it off of the floor in the winter, but I use the J&S for everything else.
Also, the Power Vision. That's great too
Synstars
Oct 26, 2019 11:34 AM
creepy
General Topics/Tech Tips
Feb 14, 2019 04:35 AM
Bluesrider.df
May 26, 2018 09:41 PM
mattVA
Jun 28, 2017 12:02 PM
Emmo
May 23, 2013 07:13 PM
