I took this out from when you pull the left side cover off and its right there. There has to be something else besides this that is controlling the flashers. On the wiring diagram I have it doesn't show anything else. Mine is the carbureted edition 2003, it is probably different from any of the fuel injection ones
Hmm... 68925-07 is a security module from 07-10 it looks like. Was this retrofitted by somebody several years ago? If so, only the guy that did the work knows how it was wired...
Item #15 in this exploded view. It replaces the turn signal module and plugs in at the same point in the harness. That's in a 07, tho. Verify if yours is the same?
Item 36 + 37 are the siren and backup battery for the security system.
Just checked the 03 WG part list. Same deal as the 07. Security module swaps in place of the turn signal module. Siren amd battery look to be under the seat and thw module appears to be inside the electronics box left of the backbone.
On your wiring diagram, it shows the connector for the signal module as well as the connector for the siren.
well my part number is 68924-00B. When I look it up its says its the european model. I'm guessing the key fobs are married to this unit. would that be correct? So if I bought model 68922 which is what is listed on the part finder pages my fobs would no longer work
That's not an inexpensive part. Might see if there is a test procedure you or the dealer can perform. Maybe even put it on a known good bike. If not, make sure you return it if it turns out that it wasn't necessary.
Theres a guy on ebay selling the main harness with the ignition module and TSSM with it for a 03 softail. I'm guessing this should be similar to my bike. Anyone know if they would be the same? or would work?
