OP~
Try this~
As you slow to a stop, say about walking speed, try shifting into neutral. See if that is easier. Tin cup is right, your clutch plates are dragging too much. You can change fluids all you want, but the best "fix" is to get familiar with your clutch adjustments.
I have a 195 Dyna Superglide Sport and I have noticed that it is next to impossible to downshift from 2nd into Neutral, the 'box simply clicks into 1st gear.
When in 1st gear, I can find Neutral easily enough but on a cold engine (early in the morning) she will shift 1st-N and then N-2nd.
All other gears are OK.
This got me thinking that perhaps the shift lever linkage is adjusted too close to "downshift" and a little too far away from "upshift".
How much should I readjust... 1/16th inch ? 1/8th ? How many flats of the adjusting nut ?
