Trouble getting fat bob in neutral
Old May 26, 2016 | 01:52 PM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by mpescatori
Hello guys, permission to cut in.
I have a 195 Dyna Superglide Sport and I have noticed that it is next to impossible to downshift from 2nd into Neutral, the 'box simply clicks into 1st gear.
When in 1st gear, I can find Neutral easily enough but on a cold engine (early in the morning) she will shift 1st-N and then N-2nd.
All other gears are OK.
This got me thinking that perhaps the shift lever linkage is adjusted too close to "downshift" and a little too far away from "upshift".
How much should I readjust... 1/16th inch ? 1/8th ? How many flats of the adjusting nut ?
Thank you
Read the owners manual. It's made to shift from 1st to neutral. Do 3/4 turn..not flats and be sure you are at no play by moving lever as you bottom for no play and two tuns in past it and then back out for no play fill. The out 1/2 -3/4 turn. Just about 1/32 to 1/16 lever play checked at full lock both directions of the bars. Keep an eye on free play. It can change but the back off once warn in rarely changes.
Old May 31, 2016 | 04:31 PM
mpescatori's Avatar
mpescatori
Thank you.
Just to be clear, I was referring to the shift linkage, not to the clutch lever.
You say "Do 3/4 turn... not flats".
OK; "flats" of a nut is a typical British system to fine tune a linkage.
You say "3/4 turn" which I take for "three quarters".
I am not sure I understand your "be sure you are at no play by moving lever as you bottom for no play and two tuns in past it and then back out for no play fill."
I take this to mean "push the gear lever down as far as it will go, keep it down and make sure there is no play in the linkage".
If there is play, "two turns in, then back out for no play".
I think I understand.
Unfortunately the owners manual on a 21y.o. bike is wishful thinking, I found one off eBay (m.y. 1996, not 1995) but it includes literally ALL Harleys produced that year...
Thank you for your advice
Old May 31, 2016 | 05:15 PM
Jackie Paper
Thank you.
Well I understand what you were referring to as flats back out but Harley says 1/2 to 3/4 turns. (one half to three quarters) . So with a hex (6 flats) it would be 3 flats for one half turn. However to get three quarters would be truly hard to make any sense of to me.
What I am referring to in the back off from the bottom is when you screw in to bottom and take all the play out, people miss this. If you screw it in to bottom and then two more turns in to deburr thread and then back out, As you go back in to find bottom, if you work the clutch lever and screw in, you will fill that little play till it disappears. That is the true no play. Then your 1/2 to 3/4 turn. Lock it there and set your lever play .062 or (2 mm) with the cable adjuster and lock it. (Note do not back off cable adjuster too far when setting the clutch backoff or the lever will not work so you can fill no play)
Old May 31, 2016 | 05:49 PM
TinCupChalice's Avatar
TinCupChalice
Ok... now we're just complicating something that's completely simple to do. With the locknut backed off and the allen seated in the adjuster screw; think the face of a clock. Where is the allen wrench at light seat of the adjuster screw? 12 o'clock? Ok, if you want a 3/4 turn out from light seat that's 3 o'clock. At light seat it's at 10 o'clock, now that makes it a 1 o'clock counterclockwise turn for a 3/4 adjustment.
Don't think so hard, it's a Harley, not the Space Shuttle
I've always used a nickel between the perch and the cable ferrule for setting the clutch cable freeplay; I don't know how that works out for the Brits but it's always worked perfectly
I posted this earlier, post #10; but read it; it's red brick stupid to do the adjustments... promise
Last edited by TinCupChalice; Jun 1, 2016 at 03:18 AM. Reason: edited to add link...
Old May 31, 2016 | 07:08 PM
Thingfish's Avatar
Thingfish
OP: Every new Harley I've ever owned has had this. It'll get better as it breaks in. It'll be completely gone after first 2,000 miles.
Mcountryman
May 30, 2017 09:56 AM
BMunro
EVO
Jan 7, 2017 02:06 AM
jmb79
Oct 16, 2013 04:43 PM
moonraker
Jan 14, 2013 12:01 PM
nathanw
Jun 2, 2010 08:13 PM
