riser stability
Old May 19, 2016 | 02:56 AM
harlot's Avatar
harlot
Default riser stability
just wondering - in terms of stability, do having a one piece clampon riser work or will these individual style riser be better?
http://www.jpcycles.com/product/5000032
or
http://www.jpcycles.com/product/5000723
Also, do I need to buy anything to mount this riser set?
I heard from others that I need bushings.
I have a 5k mile old FXDL, might be able to use what's already there or not?
Old May 19, 2016 | 03:10 AM
hetkehog's Avatar
hetkehog
I do notice the one piece clamp works better. keeps everything tight and stops from twisting some. and your bushings will work fine with that too. with the 2 piece, you might want to go with a poly bushing. might be tighter , or more ridged
Old May 21, 2016 | 09:05 AM
ackman1968's Avatar
ackman1968
It has more to do with looks, once the two piece is clamped to the bars they are essentially one piece. I have had both and couldn't tell the difference between either of them.
Old May 21, 2016 | 06:25 PM
Maxxsmart's Avatar
Maxxsmart
Either will be fine. I'd strongly recommend replacing the bushings. The stock rubber bushings are junk. Especially if you're raising the total rise of your setup. For the money, probably one of the best mods I've done.
Old May 21, 2016 | 09:42 PM
103 sedona orange's Avatar
103 sedona orange
Yes, replace the bushings.
Old May 22, 2016 | 08:08 AM
JK_Showtime's Avatar
JK_Showtime
As others have said replacing the riser bushings has more to do with the riser stability
Old May 22, 2016 | 11:50 AM
archergodwin's Avatar
archergodwin
I run individual risers with separate caps... 1.25 bars... I have no doubt they are as strong or stronger than the one piece cap setup... poly bushings.
Old May 22, 2016 | 12:28 PM
Reaperhd's Avatar
Reaperhd
This may be a stupid question but im new to harleys. Will any risers work on all models? Like fat bob risers on an 04 wg? I know you have to have the right bar diameter for said risers but are they interchangeable?
Old May 22, 2016 | 07:40 PM
harlot's Avatar
harlot
thanks guys, I'll be going 8 inch with stock low rider bars, any particular riser bushin i should buy?
Harley brand or aftermarket?
Old May 23, 2016 | 08:37 AM
multihdrdr's Avatar
multihdrdr
Same ol' same ol' (aside from bar diameter as you stated)...only Springers have difference
Wheeler92
Mar 27, 2013 08:48 AM
AdrianVall
Sep 19, 2009 12:12 PM
DTM_75
Feb 22, 2009 08:30 PM
SuperFastGlide
Nov 6, 2008 07:34 AM
ronyd
Sep 7, 2007 09:01 AM
