Finally!!!!
Old May 21, 2016 | 09:55 AM
  #31
Reindeer's Avatar
Reindeer
That tank is beautiful.
Old May 21, 2016 | 01:08 PM
  #32
Crashauto's Avatar
Crashauto
Thank you sir!
Old May 22, 2016 | 06:58 AM
  #33
rowan's Avatar
rowan
Nice work, sweet looking ride!
Old May 26, 2016 | 08:21 AM
  #34
cggorman's Avatar
cggorman
Crash, Question for you!
I'm working on my bar end blinkers (M-Disc) and the installation instructions call for an o-ring, washer, rubber sleeve, washer, nut stacked in that order. The o-ring seems like an odd fit or location. It almost seems like it should be be seated in the big groove at the blinker body (circled below). Tho, that would put it basically at the end of the grip which could interfere with throttle action.
Out of curiosity, how did you install yours?
Old May 26, 2016 | 08:30 AM
  #35
Crashauto's Avatar
Crashauto
Which size rubber sleeve are you using?
Old May 26, 2016 | 08:34 AM
  #36
cggorman's Avatar
cggorman
The biggest one. That picture was just the signal right out of the box.
Old May 26, 2016 | 08:45 AM
  #37
Crashauto's Avatar
Crashauto
When i removed it from the grip, the o ring was in that big groove and it was not in the way of the throttle. I just rolled it out of the groove to show you how i have it set up right before i twist it in the grip
Old May 26, 2016 | 08:59 AM
  #38
cggorman's Avatar
cggorman
Interesting. Thanks!
I clicked one of the 20-odd thanks buttons. Not sure if it worked. LOL
Old May 26, 2016 | 09:06 AM
  #39
Crashauto's Avatar
Crashauto
LOLOL i was wondering why there were 20 "thank you's" up there
Old May 26, 2016 | 09:07 AM
  #40
multihdrdr's Avatar
multihdrdr
You pushed the wrong one...it was the one just to left of that one
That's the most buttons I've seen so far...You're always "All in" cg, aren't you
