Kick Stand Issues
Old May 25, 2016 | 09:29 PM
JohnMn's Avatar
JohnMn
Originally Posted by crcraig
So my kick stand seems...less than great. It's for the most part fine and keeps the bike up, but it doesn't "snap" out when I put it down.
Yeah, kinda scary ain't it? But it's not a ricer,,
Originally Posted by cggorman
Crawl under the bike and check the locking tab on the stand, ramp and notch on the pivot block.
That's what you need to do. Actually crawl under and look at what they're doing. Once you "see" how it works,, you'll be more comfortable,,
But you do need to actually look at it.
Or you could heat it and bend it and get coloring to make it right and add springs and make better springs and cut a better notch and make it longer or shorter or any of the above just to make it better,, because after all the Harley "Jiffy Stand" just doesn't work to hold the bike up,, Everyone knows that,, we hear of the "Jiffy Stand" failing all the time and bikes falling over,,
Old May 26, 2016 | 05:51 PM
HarleyBob52's Avatar
HarleyBob52
Has your bike ever been lowered ?? I "modified" my stand when I lowered it to get more lean on it by grinding the tab on the stand off some... Well I ground too much off lol,, the tab is now too short to lock in the groove when in the forward position.. Like said earlier take a look underneath and make sure the tab is locking in the groove...
Old May 27, 2016 | 05:52 AM
stilup's Avatar
stilup
I changed the knuckle in the jack stand as it had way too much slop.
New spring, crimped a little better around the pin, some never seeeze and also had to add a bumper cause the stand would slap against the frame folding it.
All good.
Old May 27, 2016 | 07:28 AM
DOCGSS's Avatar
DOCGSS
Default Solution!!
I had the same issues with my "new" Harleys. There is a simple and amazingly effective add-on that takes 15 mins. to install. I bought one last year, showed it to my riding buddies and now it is on every one of there bikes. Watch the video and install instructions, easiest mod and most effective I have done.
https://notoil.com/product/the-kicker-kickstand/
Old May 27, 2016 | 08:14 AM
Whtwolf14's Avatar
Whtwolf14
Originally Posted by Jumper1
I have made it a habit to hold mine forward till weight is on it. Always seems solid then.
This...
Old May 31, 2021 | 05:54 PM
Balladromic's Avatar
Balladromic
rculbertson102
Feb 11, 2020 12:52 PM
nuttbaggerr
Jan 24, 2016 05:05 AM
Jammin1
Aug 21, 2015 02:00 PM
Surfit
Oct 11, 2006 12:54 PM
06DEUCE
Apr 27, 2006 01:00 PM
