Starter question
Old May 19, 2007 | 10:30 AM
Sabaka454's Avatar
Sabaka454
Default Starter question
I bought a starter for my 99 WG and it's a high torque starter but the jackshaft threads are 1/4-20 and the original on was a 10-32 bolt. It's not just a matter of replacing the bolt, the washer and seal, locking tang, and inner shaft would all have to be larger too. My question is did they change the design to 1/4-20 at some point? I'd rather go with the beefier design but does anyone know what year they did if they even did at all?
Old May 19, 2007 | 10:46 AM
Velocity1's Avatar
Velocity1
Default RE: Starter question
A dealer could tell you for sure and certainly someone else on here may know. Do you have any way to dimensionally comapre the starter / jackshaft assembly parts between the2 starters?Just a thought.
V1
Old May 19, 2007 | 10:55 AM
Sabaka454's Avatar
Sabaka454
It looks like just the bolt, the two washers and the inner shaft(the one that goes through the seal) are the only differences.
Old May 19, 2007 | 02:44 PM
Sabaka454's Avatar
Sabaka454
Well if anyone else runs into this problem....til 93 they used a 1/4-20 jackshaft bolt so if you get a high torque starter make sure you check it before you have your bike all apart and have to deal with this BS
99creation-evo
Jul 31, 2010 09:54 PM
terrapin88
EVO
Jul 2, 2010 02:19 PM
comsurfer2
Jun 11, 2010 02:51 PM
frantheman39
EVO
Aug 16, 2009 07:09 AM
springer96
Jun 1, 2009 05:26 PM
