clutch adjustment
Old May 19, 2007 | 02:22 PM
low06's Avatar
low06
Default clutch adjustment
so i tried to adjust my clutch last night('06 low rider)and gave up for fear of messing up the lock nut. is there a special wrench used to reach the nut? i can't get a good angle on it with a regular box end. thanks for the help.
Old May 19, 2007 | 03:06 PM
seaox's Avatar
seaox
Default RE: clutch adjustment
Two easy ways to get it done.1. Sears sells an offset box wrench, this is what I use. 2. In the do-it-yourself section, there is a suggestion to weld a nut to the end of a socket and your good to go. I don't have access to a welder so the sears craftsman wrench was the easiest.
Old May 19, 2007 | 03:48 PM
low06's Avatar
low06
no welder either seaox....i'm off to sears. thanks.
Old May 19, 2007 | 04:59 PM
flsun1's Avatar
flsun1
You'll need a 1/2" & a 9/16" to make the adjustment low06.
Old May 19, 2007 | 05:51 PM
thrillseeker's Avatar
thrillseeker
I had a buddy weld up a socket for me... you guys must know someone that welds. Even if you didn't, a shop somewhere would prolly do it for a few bucks - assuming you took in the two parts.
BiggCliff412
Oct 17, 2017 06:22 PM
Sand850
General Topics/Tech Tips
Nov 3, 2016 07:27 AM
wiktor
Apr 9, 2013 08:26 AM
badfl97
Aug 1, 2012 10:03 PM
R_W_B
Dec 9, 2010 04:12 PM
