Fork seals
Old Jun 8, 2016 | 11:12 PM
archergodwin's Avatar
archergodwin
2' piece of pvc pipe. Cut 3" off the end, square. The take that 3" piece and cut in half to give you two half circles. Then, cut a 1/2" section off the half circles.
Position your seals then take the two half sections and apply on each side of the tube, sitting on top of the seals, and use electrical tape to keep the 1/2 circles in place.
Take the original length of tube and use it as a plastic slide hammer... works like a champ.
Old Jun 13, 2016 | 07:31 AM
Justntime's Avatar
Justntime
2nd Gear
Good day i have resources for tools the fxdf fork tube is 49 mm. I c.
Thanxx. J. E
Old Jun 13, 2016 | 10:48 AM
Reindeer's Avatar
Reindeer
I used PVC pipe to hammer the seals on, worked perfectly fine for me. I don't remember the diameter, but instead of cutting it in half as archergodwin suggested, I just ground the end down to a taper to fit in the lower legs. Worked perfectly. As mentioned already, its definitely not a difficult job. The bolt on the bottom of the sliders (12mm?) was the most difficult part as I recall.
kuri77
Jun 9, 2019 09:20 PM
No U Glider
2014-2024 Touring Models
19
Jan 30, 2018 12:34 AM
cvaria
Jun 3, 2016 08:31 AM
Tgreif
Nov 25, 2009 11:26 PM
JerseyDevil
Jun 4, 2008 09:37 AM
