Fork seals
There are several videos on YouTube that can walk you through the process; you can even improvise the seal seating tool; I like the fancy Motion Pro fork seal driver but it's not mandatory to have to do the job correctly.
If you don't have a way to lift the bike and remove the forks or you're uncomfortable doing the job I'd check with the shops in your area but I'd figure they'll hit you for a minimum of 2 hours labor plus parts. A local independent shop with people who know HD's would be your best bet to get the job done correctly and less expensively than the dealer...
Even an inexpensive lift like the Harbor Freight 1500lbs motorcycle lift can get the job done. Use a 20% off single item coupon and it's $75.99 invested.
If you perform the SC Longhair mod to the lift you won't need any Dyna lift adapters. Use grade 8 hardware; I used modded HF lifts until I dropped the coin on my J&S lift.
A bit of initial expense, but doing your own work is priceless
you may be able to bite the bullet and pay them this time around but...
TinCupChalice posted the "how"for the lift if you don't want to use the HD lift adapters. it sucks to take the hit up front but it pays dividends later.
http://www.harborfreight.com/power-t...saw-62370.html
same 20% coupon hustle applies... just make it two separate transactions
ratcheting straps (a must for this job) too...i also use floor jacks to stabilize my bike on my modded lift.
i used the cro-magnon approach... two pvc pipes($4 together) and a rubber mallet ($3) to beat in the seals. 1 1/2" & 2" pvc... 2" to beat in the seal... 1-1/2" to get the stuck 2" pvc off of the tube, lol. --- there tons of other, more intelligent ways to get the seal seated
once you have the forks free of the bike, the work takes maybe 15 - 45 minutes per tube depending on comfort with the process and familiarity with the parts. i was lucky enough to have a complete set of fat bob forks to tear down for practice, then did the job on my sportster prior to doing my dyna. by the time i reached my dyna, it took all of 20 minutes or less per tube.
if you decide to DIY - we are here to help if you need... there are tons of photos and pictures and info in my signature links and about the forums.
Doing your own work on your ride is the only way; back in the day if you rode an HD and didn't turn your own wrench you were boned. There's no one who will care for your machine like you will
Welcome to the exclusive club of real owners!If you ever get a wild hair one day and want to drop the bux on a J&S lift I can guarantee, it will be some of the best money you'll ever spend. I realize it's expensive but, they can get that lift from my cold dead fingers. Expensive, and worth every damn penny I paid
