Air Cleaner Advice
Old Jun 30, 2016 | 10:57 AM
CrispyUK's Avatar
CrispyUK
2nd Gear
Default Air Cleaner Advice
Hi all,
My Lowrider was fitted, when new, with a Kuryakyn Hypercharger and V&H Big Radius pipes. It was also remapped to Stage 1.
The Hypercharger isn't my thing, and I'd rather swap it out for a different look!
Any ideas which air cleaners would work as a straight swap, without me having to pay for a remap or invest in a controller?
Thanks in advance!
Chris.
Old Jun 30, 2016 | 11:17 AM
Reindeer's Avatar
Reindeer
If its already been remapped you should be able to switch to any different air cleaner and be fine.
Old Jun 30, 2016 | 11:24 AM
nevil's Avatar
nevil
Any aftermarket intake will flow all the air you need, no remap needed. As long as your changing it, you might want to consider one that has external breathing. Your motor will be happier with it. Among others, DK Customs has some versions that you may like.
Old Jul 1, 2016 | 09:33 AM
shekmark's Avatar
shekmark
Love my DK Customs air cleaner.
Old Jul 1, 2016 | 09:38 AM
TinCupChalice's Avatar
TinCupChalice
Absolutely agree, love my 587 and venting crankcase gasses to atmosphere is the only way to go. As nevil said, several options are available to externally vent the hot, oily, oxygen depleted gas...
Old Jul 1, 2016 | 09:55 AM
MORT666's Avatar
MORT666
K&N big sucker on my glide dog dish cleaner cover.
Old Jul 2, 2016 | 08:17 AM
Rubline's Avatar
Rubline
Venting to the atmosphere is the way to go. The one thing I don't understand is, some guys install rubber tubing from the breather bolts to a filter that they either hide, or install it where it looks like it belongs. Why the filter? The crankcase is under pressure and eventually the filter will get soaked with oil and drip. With the proper amount of oil in the crankcase (half way on the stick) and using just the breather bolts, there is very little to no oil blow-by or misting coming from the breather bolts. Nothing that you can't give a quick wipe every couple of weeks.
Old Jul 2, 2016 | 08:26 AM
JohnMn's Avatar
JohnMn
Originally Posted by Rubline
The one thing I don't understand is,,,,
Why the filter?,,,
Because I don't like running my bike low on oil.
The filter is good for 5000 miles before it needs cleaning,, it doesn't "drip".
Old Jul 2, 2016 | 08:45 AM
TinCupChalice
Some of these bikes can have excessive carryover and venting; I've got one of those. I'm methodical about keeping my oil level at 3 hash marks on the stick on a cold check and using VR1 SAE 50 oil and running breather bolts my bike would look like it sat next to a fried chicken competition, the bike would be covered in a coating of oil. The front bolt would saturate my K&N air filter allowing it to drip. This wasn't after 1k miles, it would be after an afternoon ride. With breather bolts you'd better be wearing black jeans when you went for a ride
I used a horseshoe and a long drain line to vent the misting under the bike. The oil would drip out of the hose leaving quarter sized spots when she was parked; the oil was also splattering my rear tire while riding. I added a push on filter to the hose which allowed the air flow while riding to help evaporate the oil and keep it from getting on my rear tire.
I went with the under A/C filter when I removed the horseshoe breather and this seems even more effective. With shorter hoses the gasses don't seem to be condensing in the hose, they're being removed/exhausted faster and with good air flow the filter is showing no signs of oil contamination.
This is the cleanest setup I've used yet Trask Mystfree breathers and enlarging the oil drain holes in the rocker plates are coming up next but for now this is working very effectively controlling the excessive carryover/venting of this Twin Cam.
Old Jul 2, 2016 | 08:49 AM
M&P340's Avatar
M&P340
Good question. On some bikes (not all), the stock DK breather bolts smear the carb with oil mist at speed. It was pretty bad on mine. Weak umbrella valves probably. So I added the hoses/filter, only I hated it hanging low, so I stuck it up under the tank, almost out of sight. No more oil mist mess, no drip, never have to clean the filter (haven't yet anyhow).
Attached Thumbnails Air Cleaner Advice-breather-under-tank3.jpg   Air Cleaner Advice-breather-under-tank5.jpg
