Compatibility fxdls
Old Jul 13, 2016 | 04:12 PM
CEDRIC T.A.'s Avatar
CEDRIC T.A.
3rd Gear
Default Compatibility fxdls
HI I AM PRETTY NEW IN THE FORUM & I TRY TO DO MY BEST IN ENGLISH.
I JUST OWNED A 2016 DYNA LOWRIDER S (FXDLS), I WOULD LIKE TO ORDER A BURLY SLAMER LOWERING DROP KIT FOR DYNA (FORK SUSPENSION + SHORTER SHOCS 10.5''INCHES )THE SELLER TOLD ME THAT WHEN HE CONSULTED THEIR BURLY WEBSITE THE PARTS DOESN T FIT TO MY BIKE.
i AM SO DISAPPOINTED I WAS SURE THAT IF IT CAN FIT A STREETBOTB IT WOULD BE THE SAME FOR MY SCOOT .(I GET 49MM FORK TUBES)
CAN SOMEONE KNOW & HELP ME MAYBE WITH PICS, I WOULDN T LIKE TO TAKE A RISK & THROW MONEY TO GARBAGE
tHANKS IN AVANCE .
ONLY DA BEST
http://alteregokc.com/BURLY-SLAMMER-...-DYNA-06/LATER
Old Jul 13, 2016 | 08:50 PM
ktp1598's Avatar
ktp1598
All I can add is I know the LRS (FXDLS) has a cartridge in one of the front forks. Not sure the streetbob has a cartridge fork.
Old Jul 13, 2016 | 09:07 PM
Mchad's Avatar
Mchad
You could make it work. As said, one tube is a cart. Not sure about the kit you want, but if it needs standard internals, you could always pull the cartridge and order the dampening rod and other parts for that side.
Old Jul 14, 2016 | 01:00 AM
CEDRIC T.A.
3rd Gear
THANKS FOR YOUR ANSWERS , SO IF UNDERSTAND CORRECTLY THE CARTRIDGE IS ONLY IN ONE SIDE OF THE FORK?
WHAT WITH THE REAR SHOCS IN 10.5'' INCHES IT SHOOUD BE OK ??
@Mchad r satisfied wiz your memphis shade cafe fairing, i wanna orer one coz it seems to me as shorter as I need how high r your wild 1psycho handlebars?
Have a goo day guys
Old Jul 14, 2016 | 07:00 AM
Maxxsmart's Avatar
Maxxsmart
One leg has the cart, the other is standard. You can look up your parts with the link below for the dampening rod, and stock spacers you may need. From what I can tell, you'll only need a couple of small items and a dampening rod, along with some fork oil to make it a standard FXDL front end. Most websites, and vendors will not say this Slammer Kit is compatible, because you have that cart in one side, but regardless of what's inside, it's still just a standard HD 49mm front end.
http://www.stcharlesharleydavidson.c...partfinder.htm
The 10.5 inch shock should work, but keep in mind your handling, and potential for bottoming out will increase greatly.
Old Jul 14, 2016 | 08:12 AM
Mchad's Avatar
Mchad
Have a goo day guys
Yeah, I like the Cafe fairing. It's not a hugely noticible wind deflection difference over the stock one, but IMO it looks a lot better. Plus it's easily removable and can exchange for a full shield during those cold winter rides if necessary.
My bars are 8" rise. Also to note, I used a shorter headlight block, so mine is probably 3/4" lower because of that.
Old Jul 14, 2016 | 08:17 AM
NorthWestern's Avatar
NorthWestern
FXDLS in Tel Aviv. That is awesome
RDD
Feb 11, 2017 04:42 PM
californiafatbob2013
Dyna Parts
Jan 10, 2015 08:16 PM
merope
General Topics/Tech Tips
Apr 28, 2014 10:51 AM
strongwood
Apr 25, 2011 07:13 AM
user 87208922
Nov 20, 2010 01:56 PM
