Front end clunk
Old Jul 24, 2016 | 08:09 PM
Archex's Avatar
Archex
Default Front end clunk
2014 Fat Bob, when I am on the front brake and hit a small bump I get a loud bump noise in the front end. The closest I can come too describing it would be the sound 2 lb ball bearing would make if you banged it inside a wood box. It's not engine .. Sounds like it is coming from the frame neck. Any ideas?
Old Jul 24, 2016 | 08:10 PM
skid_pimp's Avatar
skid_pimp
That is where the steering neck bearings are located, it they are loose, they tend to clunk
Old Jul 24, 2016 | 08:54 PM
Suede Blue Man's Avatar
Suede Blue Man
A lot of people would say that sounds like your gas tank bolts are loose, give those two bolts and nuts a look.
Old Jul 24, 2016 | 10:05 PM
grumpy56's Avatar
grumpy56
I had the same "clunk" using brake or not. Tightened up the steering neck and the clunk is gone.
Old Jul 24, 2016 | 11:59 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Old Jul 25, 2016 | 08:16 AM
1HD1C's Avatar
1HD1C
Originally Posted by OldEnuf2NoBtr
and use a torque wrench because what YOU think is tight enough probably isn't..
Old Jul 25, 2016 | 09:22 AM
natedog_37's Avatar
natedog_37
I just fixed this on my Wide Glide last week. My rear tank bold was lose and it was making this sound.
See if you can lift the tank. Simple fix
michaeltam2k
Oct 25, 2015 11:44 PM
chuck226
Jun 15, 2015 10:05 PM
corcon
Nov 3, 2008 09:11 AM
sundancewind
Oct 14, 2007 02:37 PM
ss377
Jun 4, 2007 01:00 AM
