"06 Still missing intermittent
Old May 22, 2007 | 05:38 PM
marcss's Avatar
marcss
Default "06 Still missing intermittent
Had the 8 degree injectors changed and much better. After Laughlin it started missing again but not as bad. All of a sudden it will start acting like it's running out of gas. After awhile it will go away. Happens cold, warm, hot. No predicting. HD found nothing. Said one of the plug wires was loose.(bull, I checked that) And it ran fine for them.
I've got gas from different places (91 octane). Can't figure this out. Sensors fine. Fuel pump fine. Any ideas? Thanks!
Old May 22, 2007 | 06:53 PM
rockdoc's Avatar
rockdoc
Default RE: "06 Still missing intermittent
I've heard from several people here in town that they had problems with the high pressure feed line from the fuel pump inside the tank. It develops small pin hole leaks that intermittantly cause a severe miss and sputtering (....that's the technical term.... Don;t know if that helps but you never know.....
Old May 22, 2007 | 11:53 PM
07fxdb's Avatar
07fxdb
I am getting slight missing/sputtering on my 07, at all speeds, all revs, whenver I'm just coasting, i.e. neither accelerating or decelerating. Thought I might just be a bit picky. Will see if it goes away with more miles - just did the first service.
Old May 23, 2007 | 12:59 AM
marcss's Avatar
marcss
Yeah, same thing for me. When just cruising along. Sometimes worse than others. sometimes lasts just a short time others a long time like 20 min on and off. It has been worse when cold. But Saturday it was pretty warmed up (went a couple of miles) went a few more and parked it for about 20 min. Came back and only slightly stuttered. I've only got 8k on it.
Old May 23, 2007 | 02:41 AM
wlbowers's Avatar
wlbowers
ORIGINAL: marcss
Had the 8 degree injectors changed and much better. After Laughlin it started missing again but not as bad. All of a sudden it will start acting like it's running out of gas. After awhile it will go away. Happens cold, warm, hot. No predicting. HD found nothing. Said one of the plug wires was loose. (bull, I checked that) And it ran fine for them.
They just worked on mine for that. Had to change a couple of the pins going to the injectors. Wire was broken.
Whatever it was took 4 hours.
tcataldo
Sep 10, 2015 07:00 PM
01ragtop
Sep 17, 2013 12:27 PM
chrslefty
Jul 6, 2013 05:31 PM
Navyrep1
Jul 11, 2011 02:27 PM
Streets of Fire
Sep 29, 2009 07:15 PM
