2005 Dyna street glide electric...
Old Aug 8, 2016 | 06:31 AM
Islandstar's Avatar
Islandstar
Originally Posted by j_bee
From what I can see, one of your possible problems may be related to the accessory circuit, namely the orange/ white wire going up to your handle bar switch gear housings.
Double check your 15a accessory fuse, and not just a quick glance. If you have access to a multi meter, set it to dc volts & check across both sides of the fuse for battery voltage.
Also check your instruments fuse.
I take it things worked correctly before the bar change?
As suggested have a real close look at all the connections you made.
Blueangel makes many good points worth checking.
How did you join the wires that you cut? They need to be correctly soldered and covered with proper heat shrink protection for them to be effective and long term.
It is not uncommon for the original stock orange and white wire going to the bars to have a solder joint that allows one power wire coming up from the frame to then branch off to the indictor button, the horn button etc. Is it possible you cut that join out if there was one?
If you are able, remove the switch gear block connectors from the top frame tube ( can be fiddly to do) and disconnect the left hand switch gear connector.
On the main loom side of the left switch gear connector you've pulled out of the frame you will see an orange/white wire and a black/yellow wire pin terminal. If you join across these two carefully with a separate wire/ split pin and with the power turned on the horn should sound. Take care not to touch any other wire in case it blows the fuse.
You will also see a white and violet wire.....join this temporarily to the orange and white wire and the left indicator should flash.
If these now work then it certainly points to an issue with the wiring you've done on the handle bar wiring itself.
Checked all the fuses(for the millionth time), changed all and cleaned insert point...everything now works!!!!
Thanks for all the responses!!!
Old Aug 8, 2016 | 07:21 AM
blueangel73's Avatar
blueangel73
Awesome!
Old Aug 8, 2016 | 09:36 AM
Islandstar's Avatar
Islandstar
All is not well...the problem is with the accessory fuse. Each time I turn the ignition the fuse blows. Help...again.
Old Aug 8, 2016 | 09:59 AM
blueangel73
Did you loosen the housings? Really sounds like you have a pinched wire that is grounding out against the bars/housing.
Old Aug 9, 2016 | 03:39 PM
j_bee's Avatar
j_bee
Blueangel makes a very good point and is definitely the place to look first considering the accessory fuse is now blowing.
Place a blanket or such like on your fuel tank to protect it and then remove the clutch lever bracket and the front master cylinder bracket. Then undo both switch gear housings and have a close inspection of the wiring coming from them on both sides...pull back the black outer sheathing if necessary.
Did your new bars have recesses in them to allow the switch gear wiring to safely pass under the clutch and master cylinder brackets?
Old Aug 9, 2016 | 03:44 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by blueangel73
Maybe these will help.
Or this if you fuel injected
These images look familiar to me, LOL...
Old Aug 9, 2016 | 11:01 PM
blueangel73
You have provided a wealth of knowledge within this forum, I am just trying to share it.
Old Aug 10, 2016 | 11:51 AM
FXD2003Rider
Much appreciated, Mike!
Old Aug 14, 2016 | 11:13 AM
Islandstar's Avatar
Islandstar
thanks guys...pinched wire it was. ordered new controls.
Peteman123
Oct 25, 2018 11:56 AM
ReggieSr60
Mar 13, 2017 09:37 PM
PaMotorGuy
Jul 20, 2013 06:29 AM
vl1500
Nov 20, 2011 01:45 AM
jrock387
May 11, 2010 12:37 AM
