Electrical Issue 2012 Dyna
Old Jul 19, 2013 | 02:58 PM
PaMotorGuy's Avatar
PaMotorGuy
Stage IV
Default Electrical Issue 2012 Dyna
Just got finished installing new bars on a 2012 Dyna Wide Glide. Did a check, everything appeared fine ran the bike for a minute. Went back assured that all was tightened down, connections made, etc. Tried to start the bike again and it appears that there is no power running to the bars anymore. None of the turn signals, bike run, horn, etc work. All the rear end works including brake light from the foot break only. Any ideas?
Old Jul 19, 2013 | 04:00 PM
rooti's Avatar
rooti
did you internally wire them? If not, check all the fuses
Old Jul 20, 2013 | 06:29 AM
blueangel73's Avatar
blueangel73
If you did internal wire them, loosen each control housing and see if it changes, you might have pinched a wire, more than likely the ground, this is common.
cgrafton
Jun 3, 2018 08:46 PM
smalls78
Mar 10, 2017 12:02 AM
Islandstar
Aug 14, 2016 11:13 AM
Reindeer
Jun 19, 2012 10:23 PM
1sikbob
Jul 17, 2010 02:57 PM
