Ok, now I'm pissed -battery/starting issues continue
Thanks all
Not applicable for the S model. That issue was due to weak welds on the ignition switch bracket, causing it to rattle and potentially flip the switch. The S has no ignition switch. Run/Stop and Start button only. But thanks anyway.
I had a VIN error and it had to do with the ECM and Speedo VINs not matching. Is it possible that the speedo is causing the issue? Maybe loose cable like others have suggested or maybe the temperature inside is causing moisture to build up and short something out? Is the speedo fogging up?
FWIW, wife's FXDC with 96 engine which has no ACRs did the same thing. Vinerr, dim lights etc but the battery was 6 months old and sits on a tender. Starter was bad. It just sucked juice and barely turned. So I put a bigger one in and it's been amazing ever since.
Thanks all
Personally, I think it's a compression/compensator issue. Releases have kept it from happening to mine since installed. It would do it as a 96. When mine would do it, I'd let off the starter immediately, cycle the run switch to off, then back on and hit the starter while the pump was still priming. I don't know if it was turning it over that did the trick or what, but that worked every time.
EDIT: I went back and re-read a few posts here, and in theory, the ACRs seem very logical. I will admit, HD motors are very new to me, but the fact that I get a half crank, then stop... Then try again with no issue, that really seems like the ACRs. My question is, will the ACRs open after the first stall? Just to put it out there, I have not turned the ignition switch off when this happens, just let off the starter switch, then hit it again.
