bike died today, electrical problems
Old Sep 19, 2016 | 03:23 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Check the connections at the ignition switch under the seat. Buy a main circuit breaker for a few bucks. When CBs get hot they are more prone to open plus age is another consideration.
Old Sep 19, 2016 | 05:03 PM
chriswillrise's Avatar
chriswillrise
I lose all power to everything, even the battery acts like there is a big draw on it, it drops down to like 10v. brand new battery though
Old Sep 19, 2016 | 09:55 PM
chriswillrise
quick update, i found a short in the headlight and one in a rear turn signal. who ever had it before be used wire nuts on the headlight bucket :|. battery is sitting on the charger, i actually got the starter to click a couple times so we will see what happens once i have a charged battery
Old Sep 19, 2016 | 10:10 PM
skinman13's Avatar
skinman13
A bad ignition switch will not cause the voltage reading across the battery terminals to be low...a short somewhere will.
A low voltage reading across a known good battery after it is installed indicates a current draw somewhere significant enough to pull down the battery. If the drop is large enough, there will be smoke and or charred wires and or melted terminals somewhere. If the battery volts are dropping when you turn on the switch, you need to find and fix whatever is causing that to happen before digging any further and it ain't gonna be the switch.
I was seeing this same thing with a defective new battery...could not find anything wrong with the battery or system but the failure kept happening randomly...that drove me nuckingfutts until I finally decided to go ahead and replace the new battery because I could not find anything else wrong...have had no problems since.
Old Sep 20, 2016 | 12:58 PM
rjsimmons's Avatar
rjsimmons
Good catch. Hope that solves the problem.
James1892
Apr 6, 2019 02:42 PM
humble-iron883
Dec 4, 2017 03:15 PM
chriswillrise
Electrical/Lighting/Alarm
Sep 21, 2016 08:37 PM
NicksHDchick
Aug 19, 2013 10:20 AM
Scooter Crone
May 18, 2009 09:16 AM
